Recent Content
Why does U-Boot initially read incorrect information from the EMIF controller Read-Only registers, but later retrieve the correct information on Agilex® 3, Agilex® 5, and Agilex® 7 FPGA M-Series devices in Quartus® Prime Pro edition software 26.1.1 and earlier?
Description Due to a synchronization issue between U-Boot and the IOSSM firmware, U-Boot may read incorrect values from EMIF controller read-only registers, such as MAILBOX_HEADER and MEM_TOTAL_CAPACITY_INTF. This occurs when U-Boot accesses these registers before the IOSSM firmware has completed their initialization. Once the IOSSM firmware initializes the registers, subsequent reads return the correct values. This issue is observed in Agilex® 3, Agilex® 5, and Agilex® 7 FPGA M-Series devices when using Quartus® Prime Pro Edition Software version 26.1.1 and earlier releases. Resolution A permanent fix is planned for a future release and will include the following enhancements: The IOSSM firmware will set the MB_READY bit (bit 31) in the MAILBOX_HEADER register of the EMIF Controller to 1, indicating that the read-only registers have been fully initialized. U-Boot will poll the MB_READY bit in the MAILBOX_HEADER register and wait for it to be asserted before reading any other read-only registers in the EMIF Controller. This behavior will be enabled only when the CONFIG_IO96B_MB_READY Kconfig option is selected. To maintain compatibility with earlier IOSSM firmware versions that do not support the MB_READY bit, the CONFIG_IO96B_MB_READY option will be disabled by default.Why Do I Receive the Critical Warning IPC-40026: System Clock Frequency Mismatch in a GTS SDI II Design with Dynamic Reconfiguration?
Description Due to an issue in Quartus® Prime Pro Edition Software version 26.1.1, a critical warning may be displayed when using the GTS SDI II Design Example. This warning occurs because the SysPLL parameter is configured with the GTS PMA/FEC Direct PHY IP (TX/RX Simplex) settings instead of the GTS PMA/FEC Direct PHY IP (Dynamic Reconfiguration) settings. Resolution This warning can be safely ignored, as it does not affect the functionality or operation of the design. This problem is scheduled to be fixed in a future release of Quartus Prime Pro Edition software.Why do I see this warning message after enabled Transceiver Toolkit Debugging Features in Serial Design ?
Description Due to a problem in the Quartus® Prime Pro Edition software version 26.1.1, you will observe below. “warning check failed! > warning: no path is found satisfying assignment" “set_max_skew -from get_registers auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|stfabric|h2t1_fifo|in_wr_ptr_gray -to get_registers auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|stfabric|h2t1_fifo|write_crosser|sync.u|din_s1 -get_skew_value_from_clock_period src_clock_period -skew_value_multiplier 0.800 - This assignment will be ignored.” It happen when enabled Transceiver Toolkit Debugging Features in Serial Design. This problem happens due to undefined the path of the dc_fifo.sdc. Resolution This problem is scheduled to be fixed in a future release of Quartus Prime Pro Edition software.Why am I seeing High Severity DA warning Multiple Clock Domains Driving a Synchronizer Chain after I enabled Transceiver Toolkit Debugging Features in Dual-Simplex Parallel loopback with external and without VCXO Design Example ?
Description Due to a problem in the Quartus® Prime Pro Edition software version 26.1.1 you may see there is different clock domains driven in a synchronizer chain causing high severity DA warning in report compilation Resolution This problem is scheduled to be fixed in a future release of Quartus Prime Pro Edition software.Why does the AXI ready signal assert when EMIF calibration fails in Quartus® Prime Pro Edition 25.1.1?
Description Due to a problem in the Quartus® Prime Pro Edition Software version 25.1.1, the AXI ready signal might assert when EMIF calibration fails for designs targeting Agilex® 5 FPGA E-series devices using the EMIF IP. The AXI ready signal is asserted as expected when calibration passes, but it is also asserted unexpectedly when calibration fails. This behavior can confuse users into thinking the AXI bus is ready to access even though calibration was not successful. Resolution This problem is scheduled to be resolved in a future release of the Quartus® Prime Pro Edition Software.Why MAX® 10 FPGA programming failed when I used .jbc file with altera-stapl/JAM-STAPL player?
Description MAX® 10 FPGA programming with .jbc using altera-stapl/JAM-STAPL player failed with error log “No SLD hub”,”No SLD Node”, “Unrecognized device” and “Exit code = 6”. However, programming through Quartus® using same JBC or POF is successful. Reading ID_CODE and USER_CODE are working. Resolution Open the Quartus project’s programming or configuration-file generation settings. Enable “Enable real-time ISP to allow background programming” option. Regenerate the JAM file. Generate a new JBC from the newly created JAM file. Retry programming the MAX® 10 FPGA from the SoM using the new JBC.Why do I get "Fatal Error: Access Violation at" when running quartus_syn or quartus_fit?
Description Due to a problem in the Quartus® Prime Pro Edition Software versions 26.1 and earlier, and Quartus Prime Standard Edition Software versions 25.1 and earlier, compilation may terminate with a "Fatal Error: Access Violation" message during synthesis or fitting. This failure can occur intermittently, and the reported memory address may change between compilation runs. You may observe one or more of the following behaviors: Quartus® compilation fails during synthesis or fitting The failure may occur in either of the following modules: quartus_syn (during synthesis) quartus_fit (during fitting) The error message is similar to: *** Fatal Error: Access Violation at <<ADDRESS>> The reported memory address may change between runs. The fatal error is followed by a stack trace that includes one of the failure signatures listed below. CDB_SGATE_OTERM::adopt_fanouts HDB_ASGN_CONTAINER::remove_assignment LUTIL_DEVICE::get_fragment_from_subloc STA_NODE::reset_tag_heads DESIGN_HDB_ASSIGNMENT_CONVERTER::cleanup_after_conversion BSYN_RTM_FLOP::IsExpired RTM_ATOM_MGR::rip_out_simple_ff_for_bypass IRTM_FF_QUEUE::remove_ff PTI_BCM_TIMING_GRAPH::push_back_carry_hipi_clock_iterm FTM_TREE_NODE::num_sgates Stack traces may differ, even when compiling the same design. Specific Failure Signatures: Synthesis failure (quartus_syn): The crash report includes the following function call: RTL_ADDER::aggressive_adder_balancing Fitter failure (quartus_fit): The error occurs very early after the fitter starts, and the crash report includes the following function call: qhd_reread_global_assign_from_qsf Error Log Examples Stack Trace example for crashes in quartus_syn *** Fatal Error: Access Violation at 00007FFB92E2C63E Module: quartus_syn.exe Stack Trace: Quartus 0xc63d: CDB_SGATE_OTERM::adopt_fanouts + 0x2d (db_cdb_sgate) Quartus 0x117e7: RTL_ADDER::shrink_iports + 0x1f7 (SYNTH_OPT) Quartus 0x14a75: RTL_ADDER::create_binary_adder + 0x49e9 (SYNTH_OPT) Quartus 0x45910: RTL_ADDER::restrict_adder_network + 0x84a (SYNTH_OPT) Quartus 0x4f5d6: RTL_ADDER::aggressive_adder_balancing + 0x9d (SYNTH_OPT) Quartus 0x11533: RTL_SCRIPT::call_common_rtl_fns + 0x1043 (SYNTH_OPT) Quartus 0x115b5: RTL_SCRIPT::call_named_function + 0x8a2 (SYNTH_OPT) Quartus 0x3a87a: RTL_SCRIPT::process_script + 0x62c (SYNTH_OPT) Quartus 0x3a8e4: run_parallel_rtl + 0x1db4 (SYNTH_OPT) Quartus 0x8509d: SYNTH_QIS::SYNTHESIS_FLOW::run_parallel_rtl_in_helper_processes + 0x285 (synth_qis) Quartus 0x850d5: SYNTH_QIS::SYNTHESIS_FLOW::high_level_synthesis + 0x47d (synth_qis) Quartus 0x8546d: SYNTH_QIS::SYNTHESIS_FLOW::run_current_phase + 0x286 (synth_qis) Quartus 0x854d4: SYNTH_QIS::SYNTHESIS_FLOW::run_full_flow + 0x30d (synth_qis) Quartus 0x859b7: QIS_RTL_STAGE_IMPL::synthesize + 0x467 (synth_qis) Quartus 0x15b55: qis_synthesize + 0x245 (synth_qis) Quartus 0x16442: TclNRRunCallbacks + 0x62 (tcl86) Quartus 0x16f4d: TclEvalEx + 0x9ed (tcl86) Quartus 0xa6ab8: Tcl_FSEvalFileEx + 0x22b (tcl86) Quartus 0xa5136: Tcl_EvalFile + 0x36 (tcl86) Quartus 0x15246: qexe_evaluate_tcl_script + 0x4e6 (comp_qexe) Quartus 0x1143b: qexe_do_tcl + 0x46b (comp_qexe) Quartus 0x1a70e: qexe_run_tcl_option + 0x5ee (comp_qexe) Quartus 0x16451: QCU::DETAIL::initialize_qhd_and_run_qexe + 0xa1 (comp_qcu) Quartus 0x1f8e2: qcu_run_tcl_option + 0x2f2 (comp_qcu) Quartus 0x1b1ba: qexe_standard main + 0x26a (comp_qexe) Quartus 0x29eb: qexe_run + 0x3eb (comp_qexe) Quartus 0x1192p: qsyn2_main + 0x1a9p (quartus_syn) Quartus 0x1e808: msg_main_thread + 0x18 (CCL_MSG) Quartus 0x17021: msg_thread_wrapper + 0x71 (CCL_MSG) Quartus 0x1c89d: mem_thread_wrapper + 0x70 (CCL_MEM) Quartus 0x1b49d: msg_exe_main + 0x20d (CCL_MSG) Quartus 0x2b6c: __scrt_common_main_seh + 0x11c (quartus_syn) Quartus 0x2e8d6: BaseThreadInitThunk + 0x16 (KERNEL32) Quartus 0x5b3b: RtlUserThreadStart + 0x2b (ntdll) End-trace Stack Trace example for crashes in quartus_fit *** Fatal Error: Access Violation at 00007FFB8F79CFF7 Module: quartus_fit.exe Stack Trace: Quartus 0x1cff6: HDB_ASGN_CONTAINER::remove_assignment + 0x52 (DB_HDB) Quartus 0x1cf71: HDB_ASGN_CONTAINER::destroy_assignment + 0x31 (DB_HDB) Quartus 0xca69c: anonymous namespace::delete_all_global_assignments + 0x25c (comp_qhd) Quartus 0xcc344: qhd_reread_global_assign_from_qsf + 0x384 (comp_qhd) Quartus 0x51679: QHD_DATABASE_UTILS::load_design + 0x449 (comp_qhd) Quartus 0x1e1e0: FIT2_DATABASE_EXPERT_QDB::load + 0x5b0 (comp_fit2) Quartus 0x3xee: fit2_create_fitter_netlist + 0x3xee (comp_fit2) Quartus 0x16442: TclNRRunCallbacks + 0x62 (tcl86) Quartus 0x16f4d: TclEvalEx + 0x9ed (tcl86) Quartus 0xa6ab8: Tcl_FSEvalFileEx + 0x22b (tcl86) Quartus 0xa5136: Tcl_EvalFile + 0x36 (tcl86) Quartus 0x15246: qexe_evaluate_tcl_script + 0x4e6 (comp_qexe) Quartus 0x1143b: qexe_do_tcl + 0x46b (comp_qexe) Quartus 0x1a70e: qexe_run_tcl_option + 0x5ee (comp_qexe) Quartus 0x16451: QCU::DETAIL::initialize_qhd_and_run_qexe + 0xa1 (comp_qcu) Quartus 0x1f8e2: qcu_run_tcl_option + 0x2f2 (comp_qcu) Quartus 0x29eb: qexe_run + 0x3eb (comp_qexe) Quartus 0x16f2d: qfit2_main + 0x82d (quartus_fit) Quartus 0x1e808: msg_main_thread + 0x18 (CCL_MSG) Quartus 0x17021: msg_thread_wrapper + 0x71 (CCL_MSG) Quartus 0x1c89d: mem_thread_wrapper + 0x70 (CCL_MEM) Quartus 0x1b49d: msg_exe_main + 0x20d (CCL_MSG) Quartus 0x2b6c: __scrt_common_main_seh + 0x11c (quartus_fit) Quartus 0x2e8d6: BaseThreadInitThunk + 0x16 (KERNEL32) Quartus 0x5b3b: RtlUserThreadStart + 0x2b (ntdll) End-trace Resolution This problem is currently scheduled to be resolved in a future release of the Quartus Prime Pro Edition Software and the Quartus Prime Standard Edition Software. If you are using Quartus Prime Pro Edition Software version 26.1, apply the attached patch for your operating system: Download the Linux or Windows patch package for your platform. On Linux, install the patch package from the console. On Windows, run the patch executable file. Confirm the installation by opening the Quartus Prime GUI and checking the About window, or by running: quartus_sh -v If applying the patch is not possible, or if you need assistance with other Quartus Prime software versions, contact your local Altera support representative. Additional Information Affected software: Quartus Prime Pro Edition Software version 26.1 and earlier Quartus Prime Standard Edition Software version 25.1 and earlierWhy does the Quartus® fail Design Analysis when the 1G/2.5G/5G/10G Multirate Ethernet PHY IP and the F-Tile 1000BASE-KX Ethernet PHY IP are used in the same design?
Description Due to a problem in the Quartus® Prime Pro Edition software version 26.1, Design Analysis might fail when a design targeting Agilex® F-Tile devices instantiates both of the following IP cores in the same project: 1G/2.5G/5G/10G Multirate Ethernet PHY IP (alt_mge_phy) F-Tile 1000BASE-KX Ethernet PHY IP (intel_mge_phy_f) Both IP cores include an RTL module named alt_mge_phy_pcs. The F-Tile 1000BASE-KX Ethernet PHY version of alt_mge_phy_pcs declares an additional parameter (ENABLE_GMII_ADAPTER) that is not present in the Multirate Ethernet PHY version. When Quartus elaborates the design, the Multirate Ethernet PHY definition of alt_mge_phy_pcs can be used for both instances, which causes a parameter mismatch and compilation failure for the F-Tile 1000BASE-KX Ethernet PHY IP. Using either IP alone does not trigger this failure. Resolution A patch (26.1 patch 0.28) is available to fix this problem for the Quartus Prime Pro Edition Software version 26.1. To request the patch, contact your local Altera support representative. This problem is scheduled to be resolved in a future release of the Quartus Prime Pro Edition Software.Why does the Agilex® 5 FPGA device pin-out file list the "Direct to Factory Image" (~LOADFACTORY~) pin as an output instead of an input?
Description Due to a data error in the published Agilex® FPGA 5 device pin-out file, the optional "Direct to Factory Image" configuration signal (signal name ~LOADFACTORY~, ball BW102, 1.8-V, SDM bank) might be listed with pin direction "output" instead of "input" for designs targeting Agilex® 5 FPGAs and SoCs because the pin-out file entry for this signal has not yet been corrected to match the signal's actual, documented behavior as an input pin used to select between the factory and application images during a remote system update. Resolution To work around this problem, follow these steps: Do not use the device pin-out file as the authoritative reference for the "Direct to Factory Image" (~LOADFACTORY~) signal direction. Refer instead to the Pin Connection Guidelines: Agilex® 5 FPGAs and SoCs (doc ID: 813266), Section 1.2.14, Secure Device Manager (SDM) Optional Signal Pins, which correctly documents this pin as an input. Additional Information The device pin-out file is a board-routing reference only. It is not read or enforced by the Quartus® Prime software during design compilation or fitting, so this discrepancy causes no functional failure, no compilation error, and no design-rule violation. Customers should treat the Pin Connection Guidelines handbook (doc ID: 813266) as the authoritative source whenever it disagrees with the device pin-out file.What is the GPIO pin state after full power-up and before configuration mode for MAX® 10 FPGA devices?
Description For MAX® 10 FPGA devices, GPIO pins are typically tri-stated with weak pull-up enabled after full power-up and before configuration mode, except for the pin identified in the table below for each device package. That pin is tri-stated without weak pull-up enabled during this period, but it functions correctly in user mode. Device Package Type Y180 180-pin WLCSP M153 153-pin MBGA U169 169-pin UBGA U324 324-pin UBGA B610 610-pin VPBGA E144 144-pin EQFP 10M02 — D7 E6 C5 — 128 10M04 — D7 E6 C5 — 132 10M08 — D7 E6 C5 — 132 10M16 A5 — E6 C5 — 132 10M25 — — — — — 132 10M40 — — — — P18 133 10M50 — — — — P18 133 Device Package Type U324 324-pin UBGA F256 256-pin FBGA B610 610-pin VPBGA F484 484-pin FBGA F672 672-pin FBGA 10M02 C5 — — — — 10M04 C5 B5 — — — 10M08 C5 B5 — E8 — 10M16 C5 B5 — E8 — 10M25 — B5 — E8 — 10M40 — B5 P18 E8 E10 10M50 — B5 P18 E8 E10 Resolution This is expected behavior. If your system depends on the GPIO pin state during this period, consider adding an external pull-up resistor to the pin or selecting a different GPIO pin in your design.
Featured Content
Tags
- troubleshooting10,349 Topics
- fpga dev tools quartus® prime software pro4,295 Topics
- FPGA Dev Tools Quartus II Software3,131 Topics
- stratix® 10 fpgas and socs1,540 Topics
- agilex® 7 fpgas and socs1,507 Topics
- arria® 10 fpgas and socs1,370 Topics
- stratix® v fpgas1,312 Topics
- arria® v fpgas and socs1,225 Topics
- cyclone® v fpgas and socs1,055 Topics
- stratix® iv fpgas642 Topics
