fpga dev tools quartus ii software
3131 TopicsWhat is the maximum downward pressure that can be applied to the top of Altera BGA packages?
Description The following guidelines refer to the downward pressure or compressive load that can be applied to the top of Altera® FPGA BGA packages. Pitch (mm) Pattern Package Type Constant Compressive Load per Solder Ball (g) Eutectic SnPb (tin-lead) SAC (tin-silver-copper) 0.5 Grid MBGA 3 7 0.8 Grid UBGA 6 12 0.92 Hex FBGA 7 14 1 Hex FBGA 8 15 1 Grid FBGA 8 16 1.27 Grid BGA 12 24 Resolution For heat-sink application, Altera recommends heat sink pressure on the package between 20psi to 40psi for effective Thermal Interface Material (TIM) performance Your PCB and the supporting frame should be designed to withstand the pressure of the downward force to prevent bending or flexing of your PCB.2.1KViews1like0CommentsWhy does my transceiver RTL simulation fail to assert rx_is_lockedtodata when in internal serial loopback with Stratix 10 L/H-Tile, Arria® 10, and Cyclone® 10 GX devices?
Description An undefined “x” signal on the transceiver rx_serial_data port may cause the rx_is_lockedtodata signal to fail to assert when performing RTL simulation of Stratix® 10 FPGA L/H-Tile, Arria® 10 FPGA, and Cyclone® 10 GX FPGA devices. Resolution To perform RTL simulation of transceiver internal serial loopback, ensure that a defined state of ‘0’ or ‘1’ is applied to the transceiver rx_serial_data port in your testbench. This prevents “x” propagation into the simulation model. The ‘0’ or ‘1’ from the rx_serial_data port will be ignored when the transceiver internal serial loopback switch is enabled.237Views0likes0CommentsWhy do I get corrupted packets at XGMII receive data path using 10GBASE-R PHY IP in Stratix® IV GT FPGA device?
Description You may get corrupted packets at XGMII receive data path using 10GBASE-R PHY IP in Stratix® IV GT FPGA device, due to a timing issue in the Quartus® II software version 10.0 and 10.0SP1. Resolution If you are using 10GBASE-R in Stratix IV GT FPGA device, we recommend that you install the Quartus II software version 10.0SP1, download and apply the following patch, and recompile your design to resolve this issue: Version 10.0sp1 patch 1.166 for Windows (.exe) Version 10.0sp1 patch 1.166 for Linux (.tar) Readme for the Quartus II software version 10.0sp1 patch 1.166 (.txt)276Views0likes0CommentsHow do I address known software issues for Stratix V devices in the Quartus II software version 11.0?
Description There is a single patch available to address known software issues for Stratix® V devices in the Quartus® II software version 11.0. This patch will be updated periodically with the latest software fixes, so please check here periodically for updated files. You can refer to the readme file for the date the file was updated and a list of software fixes. Download and install the Stratix V software issue patch from the appropriate link below. Note that you should not install any non-Stratix V patches on Quartus II software version 11.0 after installing this patch. Download the version 11.0 Stratix V software issue patch for Windows (.exe) Download the version 11.0 Stratix V software issue patch for Linux (.tar) Download the Readme for the Quartus II software version 11.0 Stratix V software issue patch (.txt) Altera recommends upgrading to the Quartus II software 11.0 SP1 for designs targeting Stratix V devices.218Views0likes0CommentsHow do I address known software issues for Stratix V, Arria V and Cyclone V devices in the Quartus II software version 12.1 SP1?
Description There is a single patch available to address known software issues for Stratix® V, Arria® V, and Cyclone® V devices in the Quartus® II software version 12.1 SP1. This patch will be updated periodically with the latest software fixes. Check here periodically for updated files. You can refer to the readme file for the date the file was updated and a list of software fixes. Resolution Download and install the Stratix V/Arria V/Cyclone V device patch 1.dp7 from the appropriate link below. You must install the Quartus II software version 12.1 SP1 before installing this patch. Note that you should not install any non-Stratix V/Arria V/Cyclone V patches on the Quartus II software version 12.1 SP1 after installing this patch. Patch 1.dp7 includes all the fixes from previously-released patches. You can install 1.dp7 over the previous device patches, but you do not need to install the previous device patches before installing 1.dp7. For Windows, users must install both part 1 and part 2 to apply all fixes for patch 1.dp7. For Linux, the single patch contains all fixes for patch 1.dp7. Download the version 12.1 SP1 patch 1.dp7 part 1 for Windows (.exe) Download the version 12.1 SP1 patch 1.dp7 part 2 for Windows (.exe) Download the version 12.1 SP1 patch 1.dp7 for Linux (.tar) Download the Readme for the Quartus II software version 12.1 SP1 patch 1.dp7 (.txt) To install a previously-released version of the Quartus II software version 12.1 SP1 Stratix V/Arria V/Cyclone V device patch, select the appropriate link below. Device patch 1.dp1 Download the version 12.1 SP1 patch 1.dp1 for Windows (.exe) Download the version 12.1 SP1 patch 1.dp1 for Linux (.tar) Download the Readme for the Quartus II software version 12.1 SP1 patch 1.dp1 (.txt) Device patch 1.dp4 Download the version 12.1 SP1 patch 1.dp4 for Windows (.exe) Download the version 12.1 SP1 patch 1.dp4 for Linux (.tar) Download the Readme for the Quartus II software version 12.1 SP1 patch 1.dp4 (.txt) Device patch 1.dp6 Download the version 12.1 SP1 patch 1.dp6 for Windows (.exe) Download the version 12.1 SP1 patch 1.dp6 for Linux (.tar) Download the Readme for the Quartus II software version 12.1 SP1 patch 1.dp6 (.txt) Related Articles Errata - Known Stratix V timing model issues in Quartus II software version 12.1 SP1 The .qip/.sdc files in the project .qsf are reordered when opening a project or re-generating IP in the Quartus II software version 12.1 SP1. Why is the dedicated transceiver refclk pin Vicm lower than the specification in the Arria V GX device datasheet when using Quartus II software versions 12.1sp1 and earlier? Error (170208): Cannot place <X> nodes into a single ALM Internal Error: Sub-system: EMIF, File: /quartus/periph/emif/emif_gen5_postproc.cpp, Line: 266 Internal Error: Sub-system: FSAC, File: /quartus/fitter/fsac/fsac_clkbuf_fix_atom_netlist.cpp, Line: 1698183Views0likes0CommentsError (10232): Verilog HDL error at bitec_dp_rx_ss_audio.v(420): index 64 cannot fall outside the declared range [63:0] for vector "fifo_data_x2chan_mux"
Description Due to a problem in the Quartus® II software version 14.0, you may see this error when compiling a design that contains the DisplayPort IP that has more that 2 Audio receive channels enabled. Resolution To work around this problem in the Quartus® II software version 14.0, replace the existing file <IP variation name>/bitec_dp/rx/ss/bitec_dp_rx_ss_audio.v with the attached version of this file. bitec_dp_rx_ss_audio.v This problem has been fixed starting in the v14.1 release of the Quartus® II software.182Views0likes0CommentsWhy does Design Space Explorer only show two effort levels for performance optimization?
Description Due to a problem in the Quartus® II software version 12.0 SP2 and earlier, Design Space Explorer (DSE) may only show two available effort levels when optimizing for performance. There should be five available effort levels. This problem affects designs targeting Arria® V, Cyclone® IV, and Cyclone V devices. Resolution To fix this problem, download and install patch 2.19 from the links below. For designs targeting Arria V or Cyclone V devices, this fix is also included in device patch 2.dp3 or later from the related solution below. You must install the Quartus II software version 12.0 SP2 before installing either of these patches. Download the version 12.0 SP2 patch 2.19 for Windows (.exe) Download the version 12.0 SP2 patch 2.19 for Linux (.tar) Download the Readme for the Quartus II software version 12.0 SP2 patch 2.19 (.txt) This problem is fixed beginning with the Quartus II software version 12.1. Related Articles How do I address known software issues for Stratix V, Arria V and Cyclone V devices in the Quartus II software version 12.0 SP2?207Views0likes0CommentsHow can I address known issues with the ALTASMI_PARALLEL megafunction in the Quartus II software version 13.1?
Description There are known issues with the read_status port and Read Device Dummy Clock function in the ALTASMI_PARALLEL megafunction, in the Quartus® II software version 13.1. Refer to the Related Solutions for more information on these issues. Resolution To fix these issues, download and install Patch 0.82 for the Quartus II software version 13.1 from the appropriate link below. Download the version 13.1 patch 0.82 for Windows (.exe) Download the version 13.1 patch 0.82 for Linux (.run) Download the Readme for the Quartus II software version 13.1 patch 0.82 (.txt) Related Articles Why does the read_status port on the ALTASMI_PARALLEL megafunction not return the correct status? Why is the Read Device Dummy Clock instruction unreliable when using the QUAD and DUAL IO options on the ALTASMI_PARALLEL megafunction?209Views0likes0CommentsWhy can I not find the the coef_seq.cpp in \fir_compiler\misc, as described in the user guide?
Description The FIR MegaCore® User Guide states that both the C source code file (coef_seq.cpp) and the window executable program (coef_seq.exe) for FIR filter Coefficient Reloading and Reordering can be found in <install path>\fir_compiler\misc. However, the coef_seq.cpp file is not found here, only the coef_seq.exe is found in this directory. Resolution This issue is fixed in Quartus® II software version 13.0 or later. The workaound for previous versions is to download the coef_seq.cpp from the link below and place this file in the directory <install path>ip\altera\fir_compiler\misc: Download the coef_seq.cpp139Views0likes0CommentsError (210007): Can't locate programming file sfl_enhanced_5sgxma4k2.sof
Description You may be receiving the "Error (210007): Can\'t locate programming file sfl_enhanced_5sgxma4k2.sof" when trying to convert your Stratix ® V GX .sof file into a .jic file using the Quartus® II software version 12.0. This error is caused due to a missing sfl_enhanced_5sgxma4k2.sof file. Resolution To correct this issue you will need to download the sfl_enhanced_5sgxma4k2.sof file and place it into the \quartus\common\devinfo\programmer directory of your Quartus II software version 12.0 then regenerate your .jic file. Related Articles Internal Error: Sub-system: PGMIO, File: /quartus/pgm/pgmio/pgmio_devices.cpp, Line: 7672 Can not locate the SFL sof file: <filename>163Views0likes0Comments
