Knowledge Base Article
Error (210007): Can't locate programming file sfl_enhanced_5sgxma4k2.sof
Description
You may be receiving the "Error (210007): Can\'t locate programming file sfl_enhanced_5sgxma4k2.sof" when trying to convert your Stratix ® V GX .sof file into a .jic file using the Quartus® II software version 12.0. This error is caused due to a missing sfl_enhanced_5sgxma4k2.sof file.
Resolution
To correct this issue you will need to download the sfl_enhanced_5sgxma4k2.sof file and place it into the \quartus\common\devinfo\programmer directory of your Quartus II software version 12.0 then regenerate your .jic file.
Related Articles
Updated 4 months ago
Version 5.0
