Knowledge Base Article
Why can I not find the the coef_seq.cpp in \fir_compiler\misc, as described in the user guide?
Description
The FIR MegaCore® User Guide states that both the C source code file (coef_seq.cpp) and the window executable program (coef_seq.exe) for FIR filter Coefficient Reloading and Reordering can be found in <install path>\fir_compiler\misc. However, the coef_seq.cpp file is not found here, only the coef_seq.exe is found in this directory.
Resolution
This issue is fixed in Quartus® II software version 13.0 or later. The workaound for previous versions is to download the coef_seq.cpp from the link below and place this file in the directory <install path>ip\altera\fir_compiler\misc:
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
