Knowledge Base Article
Why does my transceiver RTL simulation fail to assert rx_is_lockedtodata when in internal serial loopback with Stratix 10 L/H-Tile, Arria® 10, and Cyclone® 10 GX devices?
Description
An undefined “x” signal on the transceiver rx_serial_data port may cause the rx_is_lockedtodata signal to fail to assert when performing RTL simulation of Stratix® 10 FPGA L/H-Tile, Arria® 10 FPGA, and Cyclone® 10 GX FPGA devices.
Resolution
To perform RTL simulation of transceiver internal serial loopback, ensure that a defined state of ‘0’ or ‘1’ is applied to the transceiver rx_serial_data port in your testbench. This prevents “x” propagation into the simulation model. The ‘0’ or ‘1’ from the rx_serial_data port will be ignored when the transceiver internal serial loopback switch is enabled.
Updated 4 months ago
Version 5.0
