Knowledge Base Article
Error (10232): Verilog HDL error at bitec_dp_rx_ss_audio.v(420): index 64 cannot fall outside the declared range [63:0] for vector "fifo_data_x2chan_mux"
Description
Due to a problem in the Quartus® II software version 14.0, you may see this error when compiling a design that contains the DisplayPort IP that has more that 2 Audio receive channels enabled.
Resolution
To work around this problem in the Quartus® II software version 14.0, replace the existing file <IP variation name>/bitec_dp/rx/ss/bitec_dp_rx_ss_audio.v with the attached version of this file.
This problem has been fixed starting in the v14.1 release of the Quartus® II software.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
