Knowledge Base Article
What is the GPIO pin state after full power-up and before configuration mode for MAX® 10 FPGA devices?
Description
For MAX® 10 FPGA devices, GPIO pins are typically tri-stated with weak pull-up enabled after full power-up and before configuration mode, except for the pin identified in the table below for each device package. That pin is tri-stated without weak pull-up enabled during this period, but it functions correctly in user mode.
Device
Package
Type
Y180
180-pin WLCSP
M153
153-pin MBGA
U169
169-pin UBGA
U324
324-pin UBGA
B610
610-pin VPBGA
E144
144-pin EQFP
10M02
D7
E6
C5
128
10M04
D7
E6
C5
132
10M08
D7
E6
C5
132
10M16
A5
E6
C5
132
10M25
132
10M40
P18
133
10M50
P18
133
Device
Package
Type
U324
324-pin UBGA
F256
256-pin FBGA
B610
610-pin VPBGA
F484
484-pin FBGA
F672
672-pin FBGA
10M02
C5
10M04
C5
B5
10M08
C5
B5
E8
10M16
C5
B5
E8
10M25
B5
E8
10M40
B5
P18
E8
E10
10M50
B5
P18
E8
E10
Resolution
This is expected behavior. If your system depends on the GPIO pin state during this period, consider adding an external pull-up resistor to the pin or selecting a different GPIO pin in your design.
Updated 3 months ago
Version 3.0
