Knowledge Base Article
Why Do I Receive the Critical Warning IPC-40026: System Clock Frequency Mismatch in a GTS SDI II Design with Dynamic Reconfiguration?
Description
Due to an issue in Quartus® Prime Pro Edition Software version 26.1.1, a critical warning may be displayed when using the GTS SDI II Design Example. This warning occurs because the SysPLL parameter is configured with the GTS PMA/FEC Direct PHY IP (TX/RX Simplex) settings instead of the GTS PMA/FEC Direct PHY IP (Dynamic Reconfiguration) settings.
Resolution
This warning can be safely ignored, as it does not affect the functionality or operation of the design.
This problem is scheduled to be fixed in a future release of Quartus Prime Pro Edition software.
Updated 3 months ago
