Knowledge Base Article
Why do I see this warning message after enabled Transceiver Toolkit Debugging Features in GTS SDI II Serial Loopback Design Example?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 26.1.1, you will observe below.
“warning check failed! > warning: no path is found satisfying assignment"
“set_max_skew -from get_registers auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|stfabric|h2t1_fifo|in_wr_ptr_gray -to get_registers auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|stfabric|h2t1_fifo|write_crosser|sync.u|din_s1 -get_skew_value_from_clock_period src_clock_period -skew_value_multiplier 0.800 - This assignment will be ignored.”
It happens when user enables the Transceiver Toolkit Debugging Features in GTS SDI II Serial Loopback Design Example. This problem happens due to the undefined path of the dc_fifo.sdc.
Resolution
This problem is scheduled to be fixed in a future release of Quartus Prime Pro Edition software.
Updated 1 month ago
Version 8.0No CommentsBe the first to comment
