Reset Release IP VHDL code not working
I am trying to create a simple VHDL design test for an Agilex 7 m-series FPGA and have hit a snag. I am trying to create a Reset Release IP code snippet and cannot seem to figure out what to do. I do not know what is declared in the IP itself and tried working with the code I saw on the RRIP video. I am attaching my code and the errors I am getting. Any help would be appreciated.
Thank you,
Drew
By the way, here is how your project netlist looks like in the RTL viewer. You should really check the connections and make sure if this is what you intended.
The connections are easily changed through portmapping as I had helped you earlier. You may check out the VHDL trainings as it covers this.
It seems like a very small project. What are you trying to do with this project? Are you just going to run simulations? Are you going to do hardware programming?
Nurina
- FvM
the message tells about VHDL syntax errors, a bit different from "not working".
It's generally a good idea to fix syntax errors from top to bottom, succeeding erors may be just aftereffects.
First errors are incorrect component declarations.
Component declarations follows this scheme
component_declaration ::=
component identifier [ is ]
[ local_generic_clause ]
[ local_port_clause ]
end component [ component_simple_name ] ;
There's no place for signals in component declaration.
You'll later notice that your component declaration, besides unexpected signal declaration are also incomplete because they don't
declare all ports of the respective components.
We would e.g. expect
component rr_ip
port(
ninit_done : out std_logic
end component;
Just to give you a starting point. You should have a VHDL text book or tutorial at hand.
- MATRIX7878
Ok, I see where I am going wrong. I still do not know where to (or rather what to declare) some of the variables as. I have tried to figure out what I need to do for the Reset Release IP but cannot get it to work. I do not know what should be a signal, a port, or something else. I am attaching my new code and errors. The Reset Release code is lines 13-27. I hope this looks better. I have tried to follow the tutorial for the Reset Release IP I found through Intel, but the code provided was pseudocode and I am still trying to figure out VHDL.
Thank you,
Drew
- Nurina
Seems to me that the Reset Release IP is correctly instantiated.
Based on the error message, the problem is due to the sys_pll component instantiation on line 26.
You were trying to connect to ports that do not exist in the sys_pll component.
Please check if the connections are correct. These threads may be helpful for you: https://www.edaboard.com/threads/problem-with-using-components-in-vhdl.374664/
Nurina
- MATRIX7878
Alright, I think I took care of that issue, but now something new has happened. I am getting an error saying that the IP may not work with my code. Did I turn on the signals wrong, or does the IP need to be its own VHDL file? I am attaching my code for review and the errors.
Thank you,
Drew
- FvM
The error message tells you that your project misses implementation code for the two instantiated components.
- Nurina
Now your Reset Release IP VHDL file does not look like Reset Release IP at all.
Are the reset release IP and sys_pll the same? Why are you combining them?
The error message is saying that you need to have an entity for both RRIP and sys_pll.
You may find these useful:
https://fpgatutorial.com/vhdl-entity-architecture-library/
https://vhdlwhiz.com/entity-instantiation-and-component-instantiation/
https://nandland.com/entity-and-architecture/
Nurina
- MATRIX7878
It does not? Dang it. I just moved all the code I needed for RRIP into its own .vhd file. I see what you mean though. I think that I am trying to keep as close as I can to the example, I saw in the Intel Reset Release IP video. It had the example I started with. I need to take that as pseudo code and work from there. What parts of the code (image attached) do I need to implement and what parts are already made in the IP itself? Am I declaring too many things? I think I am confusing many things together and am making too much code. Is there an example I can use of non-pseudocode?
Apologies for this taking a long time to get into my head, I think I keep focusing on the wrong thing.
Thank you,
Drew
- FvM
You didn't manage to write valid entity code for rr_ip and sys_pll. Apart from other details, the entity name has to match the instantiated name. E.g.
entity rr_ip ...
- FvM
O.k., resetRelease.vhd (second screenshot) contains entity declaration, but many syntax errors. Obviously it has been never compiled.
Not intended to be exhaustive:
- each entity declaration needs its own library statement- all signals used in the arcitecture must be declared, either as port or internal signal
- process needs begin statement
- signal assignment uses <= rather than => operator- can't write port signals with direction "in"
It seems to me that you filled architecture bodies with arbitrary signal assignments instead of implementing meaningful code function. I'd rather try to write entities that serve a useful purpose. - FvM
Regarding your other question, you don't necessarily need compoenent decalarations when instantiating VHDL entities, you can use
this syntax
u1: entity work.sys_pll instead of u1: sys_pll
Alos explained in the links given by Nurina - sstrell
You don't show what errors you're getting now, but here are the many issues I see:
Where is the code for component clockdiv?
Why does sys_pll.vhd have a signal in its port list named my_reset? I presume you added this in for some reason. Assuming this is generated from an IP, you should not be editing the top-level code for the IP. In the IP Parameter Editor, you should go to Generate -> Show Instantiation template and use the template there to instantiate the IP exactly as it's generated. There is no reason to edit the top-level code for a generated IP. For a basic PLL, there are only 4 signals: refclk and rst inputs, and locked and outclk_0 outputs. What are sys_clk and rst_in since there is already outclk_0 and rst? And why is locked bidirectional? It's an output status signal from the PLL. And there is no bidirectional logic in the core of an FPGA. The component declaration should simply be (from the instantiation template):
COMPONENT sys_pll is
PORT (refclk, rst: IN STD_LOGIC;
locked, outclk_0: OUT STD_LOGIC);
END COMPONENT;
ninit_done is an output of the reset release IP and yet you are connecting it to an input port in the toplevel, an input pin of the device, which makes no sense. It should be connected to reset inputs of the instantiated components or used as a status indicator. And what is sys_rst supposed to be doing? You declare it and then it's not used anywhere. The reset release IP should be used as just a status indicator that device initialization is complete. You can use it as a reset signal, but it won't ever go low again during normal operation of the device so it can't be used as a warm reset.
If you're not using the locked signal of the PLL, just leave it out of the port map. You're basically connecting a signal to itself when you say locked => locked, which makes no sense.
Speaking of port mapping, you have it backwards for the PLL. The first signal name is the name of the component's port. The signal after "=>" is the signal in this level of the design that the lower-level port is connecting to. So your PLL instantiation should probably look like this:
u1: sys_pll PORT MAP (rst_in => my_reset, clk => clk, outclk_0 => iclk);
Even this isn't perfect because what is the point of clockdiv? You can divide a clock using the PLL itself instead of needing oclk and iclk.
I highly suggest you check out some VHDL training: https://cdrdv2.intel.com/v1/dl/getContent/652842
- Nurina
Hi Drew,
Since this involves a few vhd files, can you share the .qar file of your project?
To generate this, go to Project>Archive project.
This is so that I can add the necessary code changes and you can review them.
Nurina
- MATRIX7878
Of course. Please find attached my .qar for this project. The project itself is so much easier than the RRIP part. At least it seems to be. I have yet to comment the code, but thanks to the structure of VHDL, it seems to be more self-explanatory.
Thank you,
Drew
- Nurina
Hi Drew,
Is the sys_pll suppose to be just a PLL? Where did you get this code?
Based on line 15, you are latching the sys_rst with locked and rst but there is a syntax error due to locked being an output port of the sys_pll. I'm not sure what you wanted the sys_pll to describe.
I have resolved the errors and used an IOPLL IP in place of the sys_pll.vhd. You can make changes to the IOPLL settings as you wish. I'm attaching the .qar file here shortly.
Nurina
- Nurina
Hi Drew,
Here is the .qar file with resolved code as promised.
You can check the RTL viewer to see if the connections were what you were intending.
I highly recommend these training videos since you're a beginner:
https://www.youtube.com/watch?v=bwoyQ_RnaiA&
https://www.youtube.com/watch?v=lHowLUNHFFA&
The VHDL training link shared by strell is also very useful to go through.
Nurina
- MATRIX7878
It looks good in the RTL viewer. Will need to run a simulation of course to make sure it works. I am currently enrolled in the Intel training versions of those YouTube links you shared.
While all the errors are gone, upon completing the Analysis and Synthesis step of compilation, I get the warnings attached in the image. I look at the file that the 2nd warning references and it complains that the Reset Release is not there. I'm confused. Is the IP not started? What do I need to do? I am attaching the report file as well. We were so close to me getting it. Is it because I am using an Agilex 7 M-Series? I would not see why.
Thank you for your continued support. It means a lot to me.
Drew
- MATRIX7878
I got this code from the Reset Release IP video I found on Intel's website and also on YouTube. I was following the code that I saw on that video to get the sys_rst line.
You used another IP? Ok.
Thank you,
Drew
- Nurina
I checked and it's because toplevel.vhd is not set as top level entity.
Set the toplevel.vhd as top level entity and it will resolve the RES-10204 - Reset Release Instance Count Check warning.
Ultimately you should check the RTL viewer/simulation to see if this is the circuit/functionality you were going for.
Nurina
- MATRIX7878
That solves that problem, but there is the other error that I am attaching below. I do not know why it says that the FPGA is not compatible. It sounds to me that either the FPGA cannot get out of the RRIP, or it cannot find the registers to get in. I am not sure which, if either. That should be the last thing I need help with.
Thank you,
Drew
- Nurina
Hi Drew,
I think you can ignore the Evaluation Mode warning. It doesn't seem like you're using it anyway. More info about it here: https://www.intel.com/content/www/us/en/docs/programmable/683502/17-1/an-320-using.html
You got those warnings because the reset release IP isn't connected to those registers, and in fact it isn't connected to anything in your project at all. I wasn't sure how you want to connect the reset release IP and I'm not an expert on this IP's usage. I was just helping out to fix the syntax errors.
What do you want to use this IP for? How do you want to connect it to the other modules?
You may find this useful: https://www.intel.com/content/dam/support/us/en/programmable/support-resources/bulk-container/pdfs/literature/an/archives/an891-19-3.pdf
Nurina
- MATRIX7878
I can ignore them? Good to know.
It is not connected, but it is included. I see, I will need to see how to actually use it. The only reason I even knew about the RRIP was because I got a critical warning about it. Other than that, the project was fine. I appreciate the help with the syntax errors.
I am using the IP to reset the FPGA after the circuit is programmed. I am not sure how I want to connect it to other modules. I thought that maybe it would connect itself as the IP was connected.
It seems like I need to go more in depth into that .pdf.
Thank you,
Drew
