Reset Release IP VHDL code not working
- 3 years ago
By the way, here is how your project netlist looks like in the RTL viewer. You should really check the connections and make sure if this is what you intended.
The connections are easily changed through portmapping as I had helped you earlier. You may check out the VHDL trainings as it covers this.
It seems like a very small project. What are you trying to do with this project? Are you just going to run simulations? Are you going to do hardware programming?
Nurina
Hi Drew,
Since this involves a few vhd files, can you share the .qar file of your project?
To generate this, go to Project>Archive project.
This is so that I can add the necessary code changes and you can review them.
Nurina
Of course. Please find attached my .qar for this project. The project itself is so much easier than the RRIP part. At least it seems to be. I have yet to comment the code, but thanks to the structure of VHDL, it seems to be more self-explanatory.
Thank you,
Drew
