  • sstrell's avatar
    sstrell
    It's not clear what the issue is.  Can you not use Quartus 25.1?
    • Beroual's avatar
      Beroual
      For my projects
      Using version 25.1 requires some adjustments.
      I need version 17.0, which requires no adjustments.
    • Beroual's avatar
      Beroual
      Hello
      I tried to open the exemple in the source
      "Detailed Description • Arria® 10 FPGA – Simple Socket Server for the Nios® V/m Processor Design Example • Altera Documentation and Resources Center"
      The example file "top.par"
      But unfortunately, I couldn't open it
      I keep getting the message: "Design template installation failed."
      is there any solution? Thanks in advance.
      • ShengN_altera's avatar
        ShengN_altera
        Make sure use the supported version for the example design
    ShengN_altera
    Please use the latest version 25.1.
    Legacy version need legacy license (most of them are obsolete already)
    • Beroual's avatar
      Beroual
      for my project:
      I need version 17.0, which doesn't require any adjustments.
        ShengN_altera
        Nios II you can get from Altera SSLC:
        Triple speed ethernet license you may need to approach regional distributor for that IP license
  • Beroual's avatar
    Beroual
    version 23.1      It behaves like version 17.0   also
