Beroual
6 months agoThe quartus license works with version 25.0 but not with version 17.0
Hello, I recently purchased a Quartus license. Unfortunately, it works with Quartus version 25.0, but not with version 17.0. Is there a solution for this? Thank you in advance Beroual
sstrell
6 months agoIt's not clear what the issue is. Can you not use Quartus 25.1?
- Beroual6 months ago
For my projects
Using version 25.1 requires some adjustments.
I need version 17.0, which requires no adjustments.
- ShengN_altera6 months ago
How about 18.0? Can work?
version 18.0 It behaves like version 17.0
- Beroual5 months ago
Hello
I tried to open the exemple in the source
"Detailed Description • Arria® 10 FPGA – Simple Socket Server for the Nios® V/m Processor Design Example • Altera Documentation and Resources Center"
The example file "top.par"
But unfortunately, I couldn't open it
I keep getting the message: "Design template installation failed."
is there any solution? Thanks in advance.
- ShengN_altera5 months ago
Make sure use the supported version for the example design
