USB Blaster III and Cyclone III
Cyclone III is supposed to be supported by USB Blaster III.
I was wondering which Quartus version would be needed?
Last Quartus version for Cyclone III is 13,1 as far as I know. Is USB Blaster III working with 13.1?
best regards
Ben
Hi Ben,
Quartus 13.1 can use recent (e.g. Quartus 25.1) JTAG server to access USB Blaster III. Additionally installing Quartus Prime Programmer and Tools 25.1 will do if you don't need full Quartus installation.
Regards Frank
- FvM
Hi Ben,
as far as I see, USB Blaster III (as well as other newer programmer cables like USB Blaster II or Arrow Blaster) even works with Quartus 9.0 for legacy FPGA. Because old programmer tool and SignalTap setup has no JTAG frequency setting, it may be necessary to use jtagconfig command line interface.
Frank - ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
- KennyT_altera
Good question, Ben — and you've identified the core tension correctly. Let me lay out what the documentation confirms:
The USB Blaster III FPGA Development Cable does list Cyclone III as a supported device family for configuration data. USB Blaster III FPGA Development Cable User Guide However, Cyclone III support was removed from Quartus II software starting with version 14.0 — the last version that supported Cyclone III was 13.1. You must use Quartus II software version 13.1 to design with that device family. Quartus® II Software and Device Support Release Notes Version 14.0
The critical gap here is that the USB Blaster III is a modern cable, and the documentation does not explicitly state which minimum Quartus version is required to use it. The Quartus Prime Standard Edition 25.1std release notes mention that USB Blaster III FPGA Development Cable driver installation support was added as an "after-install action" in the Quartus Prime installer New Features and Enhancements — which strongly suggests the USB Blaster III is tied to relatively recent Quartus Prime releases, not the legacy Quartus II 13.1 era.
In short: while Cyclone III is on the USB Blaster III's supported device list, Quartus II 13.1 predates the USB Blaster III cable by many years, and there is no documentation confirming that USB Blaster III is usable within Quartus II 13.1. The practical concern is that the USB Blaster III driver and JTAG server integration may require a Quartus Prime version far newer than 13.1, even if you are only targeting a Cyclone III device for programming purposes.
You may want to check the USB Blaster III User Guide's minimum Quartus version requirements section for the exact supported software version range, as that specific mapping is not captured in the available documentation here. - KennyT_altera
Do you have further question?
- FvM
Hi Ben,
Regards Frank
- ben_mecke
Hi Kenny, Hi Frank,
thanks for your messages. I was thinking that USB Blaster might work with 13.1 when you install Quartus >25.1. It does it like htis with 17.1. I could test it. I will give it a try.
Cheers Ben
- KennyT_altera
yes, it should be the case. it is backward compatible.
- KennyT_altera
yes, it is backward compatible but The documentation is explicit on this point: the USB Blaster III requires Quartus Prime version 25.1 or later. Install the latest version and patches to ensure full compatibility with the USB Blaster III FPGA Development Cable. USB Blaster III FPGA Development Cable User Guide
You may need to take your own risk on using it while if there are any bugs happened, Altera will not support it.
Also worth noting: the supported OS list for the USB Blaster III is Windows 10/11 (64-bit), Windows Server 2019/2022 (64-bit), and Red Hat Enterprise 8.6 and above USB Blaster III FPGA Development Cable User Guide — so older OS environments that typically ran Quartus II 13.1 are also out of scope.
If you're working with a legacy design flow on an older Quartus version, I'd recommend using the USB-Blaster II instead, which has a much broader software compatibility range.
- KennyT_altera
Do you have further queries? If no, we shall close this case
- KennyT_altera
closing the case
