LVDS SERDES IP, Agilex 3, Quartus 26.3
We have encountered a potential regression in the LVDS SERDES IP between Quartus Prime Pro 26.1 and 26.3 when targeting the Agilex 3 (A3CZ025BB18A).
Environment:
- Quartus Prime Pro 26.1 – LVDS SERDES IP version 24.1.0
- Quartus Prime Pro 26.3 – LVDS SERDES IP version 25.0.0
- Device: A3CZ025BB18A
- Interface: LVDS SERDES, RX, 8:1, source-synchronous external clock
- I/O standard: TDS_1P3
Problem description:
The exact same project compiles successfully with Quartus 26.1 but fails during Fitter in Quartus 26.3.
The error reports a termination conflict between the physical I/O pin and the LVDS SERDES byte:
- Physical pin assignment: DIFF_TERMINATION = DIFF
- I/O buffer termination: TERMINATION_RT_DIFF
- SERDES byte parameter: PINxxxx_DIFF_TERMINATION_RT_OFF
I verified that all differential input pins have the correct DIFF_TERMINATION assignment in the QSF.
HDL generation difference:
In LVDS SERDES IP version 24.1.0 (Quartus 26.1), the generated HDL assigns:
TERMINATION_RT_QPDS_UNSET
to the RX byte differential termination parameter.
In LVDS SERDES IP version 25.0.0 (Quartus 26.3), the generated HDL explicitly assigns:
TERMINATION_RT_OFF
for RX pins.
Changing this assignment back to TERMINATION_RT_QPDS_UNSET in the generated HDL allows Quartus 26.3 to complete the Fitter successfully.
Questions:
- Was the change from TERMINATION_RT_QPDS_UNSET to TERMINATION_RT_OFF intentional in LVDS SERDES IP version 25.0.0?
- Is this a known issue or regression affecting Agilex 3 true differential inputs using TDS_1P3?
- What is the correct recommended configuration to use the internal 100-ohm differential termination with the LVDS SERDES RX interface?
- Is there a newer IP version, patch, or recommended workaround that avoids modifying generated HDL files?
- Does using TERMINATION_RT_QPDS_UNSET preserve the intended internal 100-ohm differential termination when DIFF_TERMINATION = DIFF is assigned in the QSF?
We would appreciate clarification on whether this is an IP generation issue or a Fitter issue in Quartus 26.3.
Best regards
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
