Problem with Licence for questa_fse for Quartus 26.1
I have a problem with Questa_fse, i use FPGA Agilex 3.
I use the No-cost licence for Quartus Pro 26.1.
The simulation Work before.
Now, When I Start Questa a have this windows
Thank you for Help
1 Reply
- ai_responder
Community Manager
The error means
SALT_LICENSE_SERVERis not pointing to your Questa – Altera FPGA Starter Edition license file. The Questa – Altera FPGA Starter Edition requires a license key (at no cost), and it does not support companion licenses. Table 10. Summary of Altera FPGA Software Licenses Required — Altera FPGA Software Installation and Licensing Note thatLM_LICENSE_FILEandMGLS_LICENSE_FILEare deprecated — future versions of Questa – Altera FPGA Edition will not read them. You must set the license throughSALT_LICENSE_SERVER. 5. Licensing Altera FPGA Software — Altera® FPGA Software Installation and Licensing
Step 1 — Acquire the free license (if you haven't yet)
To obtain licenses for Agilex 3 FPGA and Questa – Altera FPGA Starter Edition from the License Setup Required dialog, select the desired licenses and click Acquire. Acquiring Free, No-Cost Licenses Alternatively, from within the Quartus Prime Pro Edition software GUI, navigate to Tools > License Setup, then click the Get no-cost licenses button to obtain the Questa – Altera FPGA Starter Edition license. Acquiring Free, No-Cost Licenses
Step 2 — Set SALT_LICENSE_SERVER
After acquiring the license file, set the environment variable before launching Questa:- Linux: Set
SALT_LICENSE_SERVERto. Acquiring Free, No-Cost Licenses/.altera.quartus/quartus2_lic.dat - Windows: Set
SALT_LICENSE_SERVERto. Acquiring Free, No-Cost Licenses/quartus2_lic.dat
SALT_LICENSE_SERVERwith the path to yourlicense.datfile. The separator between license server locations must be semicolon (;) instead of a colon (:). 5. Licensing Altera FPGA Software — Altera® FPGA Software Installation and Licensing
Step 3 — Check for mgcld daemon issue (if error persists)
In Questa FPGA Edition and Questa FPGA Starter Edition version 2024.1, this error can occur when using themgclddaemon v11.16.4. The workaround is to upgrade to the Siemens Flexlm (SALTD) daemon v11.19.5 from the download page. Error : FLEXlm version of vendor daemon is too old For floating license servers, manually change the VENDOR daemon line in the license file frommgcldtosaltd; do not change any INCREMENT lines (leave them with the original vendor daemon namemgcld). Error : FLEXlm version of vendor daemon is too old
After settingSALT_LICENSE_SERVERcorrectly, restart Questa and the fatal license error should be resolved.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
- Linux: Set
