USB Blaster III and Cyclone III
- 1 month ago
Hi Ben,
Quartus 13.1 can use recent (e.g. Quartus 25.1) JTAG server to access USB Blaster III. Additionally installing Quartus Prime Programmer and Tools 25.1 will do if you don't need full Quartus installation.
Regards Frank
Good question, Ben — and you've identified the core tension correctly. Let me lay out what the documentation confirms:
The USB Blaster III FPGA Development Cable does list Cyclone III as a supported device family for configuration data. USB Blaster III FPGA Development Cable User Guide However, Cyclone III support was removed from Quartus II software starting with version 14.0 — the last version that supported Cyclone III was 13.1. You must use Quartus II software version 13.1 to design with that device family. Quartus® II Software and Device Support Release Notes Version 14.0
The critical gap here is that the USB Blaster III is a modern cable, and the documentation does not explicitly state which minimum Quartus version is required to use it. The Quartus Prime Standard Edition 25.1std release notes mention that USB Blaster III FPGA Development Cable driver installation support was added as an "after-install action" in the Quartus Prime installer New Features and Enhancements — which strongly suggests the USB Blaster III is tied to relatively recent Quartus Prime releases, not the legacy Quartus II 13.1 era.
In short: while Cyclone III is on the USB Blaster III's supported device list, Quartus II 13.1 predates the USB Blaster III cable by many years, and there is no documentation confirming that USB Blaster III is usable within Quartus II 13.1. The practical concern is that the USB Blaster III driver and JTAG server integration may require a Quartus Prime version far newer than 13.1, even if you are only targeting a Cyclone III device for programming purposes.
You may want to check the USB Blaster III User Guide's minimum Quartus version requirements section for the exact supported software version range, as that specific mapping is not captured in the available documentation here.
