QuartusIQ VS Code extension: `@QuartusIQ` fails when asked to run `ls`
Environment:
- QuartusIQ VS Code extension `altera.quartus-pilot-vscode` 0.10.8
- VS Code on Linux
- Model: Gemini 4 Hydrogen
Steps to reproduce:
- Open a folder in VS Code and start a new chat.
- Send `@QuartusIQ hi`. It responds correctly.
- Send `@QuartusIQ run "ls" command in my current directory`.
- The request fails with the error below.
Expected: QuartusIQ lists the files in the current directory, using the `ls` tool listed in the user guide.
Logs:
2026-11-25 15:23:51.864 [info] Activating build c933603-559 (3c2f087) 2026-10-16T07:56:01Z
2026-11-25 15:23:51.864 [info] Telemetry reporter initialised
2026-11-25 15:23:51.864 [info] Trace export enabled (otel=https://qiq-otel-prd.altera.com/api/public/otel environment=prod)
2026-11-25 15:23:51.864 [info] Apply handler and diff provider registered
2026-11-25 15:23:51.864 [info] Copilot compatibility probe command registered
2026-11-25 15:23:51.864 [info] [Checkpoints] LangGraph database: /home/abdulraouf/.config/Code/User/workspaceStorage/3620cb3f350c61db81e64397aa0c599a/Altera.quartus-pilot-vscode/langgraph-checkpoints/checkpoints.sqlite
2026-11-25 15:23:51.864 [info] [Filesystem] Workspace root: /home/abdulraouf/Downloads
2026-11-25 15:23:51.864 [info] [MCP] starting child process: /snap/code/281/usr/share/code/code
2026-11-25 15:23:51.864 [info] Chat participant registered
2026-11-25 15:23:51.864 [info] [MCP] {"timestamp":"2026-11-25T10:23:50.842Z","event":"programmer_start","level":"INFO","logger":"ProgrammerRuntime","tool":"server","phase":"start","msg":"server","session_id":"ccf6a57bcfeb","pid":343221,"audit_log":null,"audit_log_env":"QUARTUS_AUDIT_LOG_FILE"}
2026-11-25 15:23:51.864 [info] [MCP] {"level":30,"time":"2026-11-25T10:23:51.004Z","event":"mcp.tools.registered","changed":true,"added":["search_altera_docs","search_quartus_msgs","search_ip_knowledge_graph","search_community_docs","lookup_drc_rules","search_reference_designs","get_quartus_report_index_status","get_quartus_signoff_verdict","get_quartus_report_sections","read_quartus_report_sections","get_related_report_context","get_quartus_timing_issue_context","analyze_bitstream","generate_programming_file","generate_helper_image","generate_rsu_jic","check_pr_compatibility","compare_files","analyze_flash_compatibility","read_jtag_config","read_config_status","program_sram_device","program_flash_device","check_qspi_flash","read_qspi_manufacturer_id"],"removed":[],"updated":[],"total":25,"inventory":{"search":["search_altera_docs","search_quartus_msgs","search_ip_knowledge_graph","search_community_docs","lookup_drc_rules","search_reference_designs"],"host":["get_quartus_report_index_status","get_quartus_signoff_verdict","get_quartus_report_sections","read_quartus_report_sections","get_related_report_context","get_quartus_timing_issue_context","analyze_bitstream","generate_programming_file","generate_helper_image","generate_rsu_jic","check_pr_compatibility","compare_files","analyze_flash_compatibility","read_jtag_config","read_config_status","program_sram_device","program_flash_device","check_qspi_flash","read_qspi_manufacturer_id"]},"msg":"MCP tool inventory registered"}
2026-11-25 15:23:51.864 [info] [MCP] QuartusIQ MCP Server running on stdio...
2026-11-25 15:23:51.864 [info] [MCP] {"level":30,"time":"2026-11-25T10:23:51.005Z","event":"mcp.server.started","msg":"QuartusIQ MCP Server running on Stdio"}
2026-11-25 15:23:51.864 [info] [MCP] connected (pid=343221)
2026-11-25 15:23:56.916 [info] [MCP] {"level":30,"time":"2026-11-25T10:23:56.915Z","dbPath":"/home/abdulraouf/Downloads/.quartus/report-index/reports.sqlite","msg":"Quartus report index refreshed"}
2026-11-25 15:24:00.058 [info] [chat] Progress UI: stable (chatParticipantAdditions unavailable; use Extension Development Host, VS Code Insiders, or enable-proposed-api for Altera.quartus-pilot-vscode)
2026-11-25 15:24:00.058 [info] [Model] name="Gemini 4 Hydrogen" id="models/gemini-4-hydrogen" vendor="gemini" family="models/gemini-4-hydrogen" version="1.0.0" maxInputTokens=983040
2026-11-25 15:24:00.058 [info] [Filesystem] Approval store loaded: /home/abdulraouf/.config/Code/User/workspaceStorage/3620cb3f350c61db81e64397aa0c599a/Altera.quartus-pilot-vscode/filesystem-approvals.json
2026-11-25 15:24:00.088 [info] [MCP] Resolved 25 tools: search_altera_docs, search_quartus_msgs, search_ip_knowledge_graph, search_community_docs, lookup_drc_rules, search_reference_designs, get_quartus_report_index_status, get_quartus_signoff_verdict, get_quartus_report_sections, read_quartus_report_sections, get_related_report_context, get_quartus_timing_issue_context, analyze_bitstream, generate_programming_file, generate_helper_image, generate_rsu_jic, check_pr_compatibility, compare_files, analyze_flash_compatibility, read_jtag_config, read_config_status, program_sram_device, program_flash_device, check_qspi_flash, read_qspi_manufacturer_id
2026-11-25 15:24:00.088 [info] [HITL] Tool approval enabled for: program_sram_device, program_flash_device, check_qspi_flash, write_file, edit_file, request_external_source_access, update_approval_policy
2026-11-25 15:24:00.192 [info] [Langfuse] CallbackHandler constructed sessionId=626c4d17-4600-4490-be93-e19519734b71 tags=vscode,real
2026-11-25 15:24:00.390 [info] [Context] window=983040 tools=0 reserve=2048 usable=980992 trigger=735744 keep=98099
2026-11-25 15:24:00.434 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task.
2026-11-25 15:24:03.889 [info] [stream] Complete. main agent chunks: 1, subagent chunks: 0
2026-11-25 15:24:46.815 [info] [chat] Progress UI: stable (chatParticipantAdditions unavailable; use Extension Development Host, VS Code Insiders, or enable-proposed-api for Altera.quartus-pilot-vscode)
2026-11-25 15:24:46.816 [info] [Model] name="Gemini 4 Hydrogen" id="models/gemini-4-hydrogen" vendor="gemini" family="models/gemini-4-hydrogen" version="1.0.0" maxInputTokens=983040
2026-11-25 15:24:46.816 [info] [Langfuse] CallbackHandler constructed sessionId=626c4d17-4600-4490-be93-e19519734b71 tags=vscode,real
2026-11-25 15:24:46.929 [info] [Context] window=983040 tools=19317 reserve=2048 usable=961675 trigger=721256 keep=96167
2026-11-25 15:24:46.961 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task.
2026-11-25 15:24:49.810 [error] Chat participant error: VS Code language model response stream failed: {"error":{"message":"{\n \"error\": {\n \"code\": 503,\n \"message\": \"This model is currently experiencing high demand. Spikes in demand are usually temporary. Please try again later.\",\n \"status\": \"UNAVAILABLE\"\n }\n}\n","code":503,"status":"Service Unavailable"}}
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
