Quartus Pro 26.3 Stratix 10 1 GbE config issue
If I configure Triple Speed 1 GbE with FIFO off, the configurator is in an error state, so I can't generate the example, but if I check the box to enable the FIFO and try to generate the example, the builder errors. Per documentation, FIFO should be off, so the configuration checker is wrong.
Stratix 10 E-tile, TSE MAC_PCS_2xTBI, internal FIFO off, transceiver None.
The Example Design generator errors with 'There is no interface named tbi_connection on instance i_tse_pcs_0'; Generate HDL works.
Device: Stratix 10, 1ST040EH2F35E2VG (E-tile), speed grade 2.
IP: Triple-Speed Ethernet (altera_eth_tse).
Parameter Setting
Core variation 10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII 2XTBI PCS (MAC_PCS_2xTBI)
Use internal FIFO Off
Transceiver type None
Enable SGMII bridge Off
Enable timestamping Off
Enable ECC protection Off
Use misc ports On
Half duplex, flow control, VLAN, GMII loopback Off
Magic packet detection On (default, unused)
TX PLL (greyed with transceiver None) CMU, 1250 Mbps base rate, x1
E-tile dynamic reconfiguration / deterministic latency Off
1 Reply
- ai_responder
Community Manager
Two separate root causes are at play here, and the documented design example settings resolve both.
Root cause of the "tbi_connection" generator error
The documented Fifoless design example for Stratix 10 E-tile sets Enable SGMII bridge: Selected in the TSE IP, with Use internal FIFO: Not selected and Transceiver type: None. Table 5. Design Components — Triple-Speed Ethernet Stratix 10 FPGA IP Design Example User Guide Your configuration has SGMII bridge off. The example design generator instantiates the external E-tile Native PHY and wires it to the TSE PCS via a TBI connection; thattbi_connectionport oni_tse_pcs_0only exists when the SGMII bridge is enabled. With it off, the interface is absent and the generator fails with that exact error. Enable SGMII bridge and re-generate.
Root cause of the configuration checker error (FIFO off)
The 2XTBI PCS variation is only supported when Stratix 10 E-tile or Agilex 7 E-tile devices are selected. You can only turn off Use internal FIFO for this variation when a Stratix 10 E-tile device is selected starting from Quartus Prime software version 20.4. When FIFO is on, the embedded PMA is included and is not optional. When FIFO is off, the embedded PMA is excluded and you must manually connect the variant to the E-Tile transceiver or external PHY that supports the 2XTBI interface. Core Configuration So FIFO off is correct — the IP is working as documented. If the parameter editor still flags it, the device in the project file needs to be explicitly set to an E-tile device before you open the parameter editor; the checker may default to a non-E-tile context.
Speed grade constraint
The generation procedure requires a Stratix 10 device with transceiver tile E-tile, transceiver speed grade -1, and core speed grade -1. Generating the Design Example Your part (1ST040EH2F35E2VG) is transceiver speed grade -2 and fabric speed grade -2. The example design generator and the development-kit QSF target the -1 grade device. Under Target Development Kit you can select the Stratix 10 TX Transceiver Signal Integrity Development Kit or select None. If you select a specific development kit, the example is generated for that device and overwrites what you selected in your project file. If you select None, ensure the selected device is your targeted device and adjust pin assignments in the .qsf file. Generating the Design Example Select None, target your specific OPN, and manually assign pins.
Known tool version issues
For Quartus Prime Pro Edition software version 21.2, a patch is required to generate the 10/100/1000Mb Ethernet MAC (Fifoless) with 2XTBI PCS with E-Tile GXB Transceiver design example — refer to the KDB article "Why does the Stratix 10 E-Tile Triple-Speed Ethernet IP Design Example generation fail?" to download the patch. Triple-Speed Ethernet Stratix 10 FPGA IP Design Example User Guide — Triple-Speed Ethernet Stratix 10 FPGA IP Design Example User Guide The design example in Quartus Prime Pro 21.1 does not support hardware test. This problem is fixed starting with Quartus Prime Pro version 21.3; a patch for version 21.2 is also available. The Intel® Stratix® 10 E-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example is not functional in hardware. If you are on 21.1 or 21.2, apply the relevant patch or upgrade to 21.3 or later.
Summary of corrective steps:- Set Enable SGMII bridge: On — this is what the example generator expects for the Fifoless 2XTBI variant.
- Keep Use internal FIFO: Off and Transceiver type: None — this matches the documented reference design.
- Set Target Development Kit to None, target 1ST040EH2F35E2VG, and adjust .qsf pin assignments manually.
- Ensure you are on Quartus Prime Pro 21.3 or later (or apply the 21.2 patch).
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
