Knowledge Base Article
The Intel® Stratix® 10 E-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example is not functional in hardware.
Description
The Intel® Stratix® 10  E-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example available in the Intel® Quartus® Prime Pro Edition Software versions 21.1 supports simulation using the provided testbench in both Synopsys* VCS* and Mentor* Modelsim.
Hardware test is not supported in version 21.1 of the Intel® Quartus® Prime Software.
The timing analyzer may report timing violations when compiling the example design in version 21.1 of the Intel® Quartus® Prime Software.
Resolution
To work around this problem in Intel® Quartus® Prime Pro Edition Software version 21.1, install the patch below:
Download the version 21.1 patch 0.15 for Linux (.run)
Download the version 21.1 patch 0.15 for Windows* (.exe)
Download the Readme for version 21.1 patch 0.15 (.txt)
This problem is fixed starting with the Intel® Quartus® Prime Pro Software version 21.3.
A patch for version 21.2 of the  Intel® Quartus® Prime Pro Software is available from the link below:
Why does the Intel® Stratix® 10 E-Tile Triple-Speed Ethernet Intel® FPGA IP Design Example generation fail?
Updated 4 months ago
Version 5.0
