USB Blaster III and Cyclone III
- 1 month ago
Hi Ben,
Quartus 13.1 can use recent (e.g. Quartus 25.1) JTAG server to access USB Blaster III. Additionally installing Quartus Prime Programmer and Tools 25.1 will do if you don't need full Quartus installation.
Regards Frank
Hi Kenny, Hi Frank,
thanks for your messages. I was thinking that USB Blaster might work with 13.1 when you install Quartus >25.1. It does it like htis with 17.1. I could test it. I will give it a try.
Cheers Ben
yes, it should be the case. it is backward compatible.
- KennyT_altera1 month ago
yes, it is backward compatible but The documentation is explicit on this point: the USB Blaster III requires Quartus Prime version 25.1 or later. Install the latest version and patches to ensure full compatibility with the USB Blaster III FPGA Development Cable. USB Blaster III FPGA Development Cable User Guide
You may need to take your own risk on using it while if there are any bugs happened, Altera will not support it.
Also worth noting: the supported OS list for the USB Blaster III is Windows 10/11 (64-bit), Windows Server 2019/2022 (64-bit), and Red Hat Enterprise 8.6 and above USB Blaster III FPGA Development Cable User Guide — so older OS environments that typically ran Quartus II 13.1 are also out of scope.
If you're working with a legacy design flow on an older Quartus version, I'd recommend using the USB-Blaster II instead, which has a much broader software compatibility range.
