Reset Release IP VHDL code not working
- 3 years ago
By the way, here is how your project netlist looks like in the RTL viewer. You should really check the connections and make sure if this is what you intended.
The connections are easily changed through portmapping as I had helped you earlier. You may check out the VHDL trainings as it covers this.
It seems like a very small project. What are you trying to do with this project? Are you just going to run simulations? Are you going to do hardware programming?
Nurina
I checked and it's because toplevel.vhd is not set as top level entity.
Set the toplevel.vhd as top level entity and it will resolve the RES-10204 - Reset Release Instance Count Check warning.
Ultimately you should check the RTL viewer/simulation to see if this is the circuit/functionality you were going for.
Nurina
- MATRIX78783 years ago
That solves that problem, but there is the other error that I am attaching below. I do not know why it says that the FPGA is not compatible. It sounds to me that either the FPGA cannot get out of the RRIP, or it cannot find the registers to get in. I am not sure which, if either. That should be the last thing I need help with.
Thank you,
Drew
