Recent Content
Why does the dynamic reconfiguration simulation of Phylite IP design fail in the Questa* – Altera® FPGA Edition ?
Description Due to a problem in the External Memory Interfaces (EMIF) IP, simulation running in the Questa* – Altera® FPGA Edition might fail when you set the use dynamic reconfiguration on Agilex® 7M R0 devices. Resolution To work around this problem, change the device selection to a non-R0 OPN during simulation.Why does the Quartus® Prime Pro Edition Software report that no IOPLL is available when placing the Low Latency E-Tile 40G Ethernet FPGA IP in an HPS shared GPIO Bank?
Description Due to a clocking limitation of HPS Shared GPIO Bank, the Low Latency E-Tile 40G Ethernet FPGA IP cannot be placed in an HPS Shared GPIO Bank when a design targets Agilex® 7 FPGA F-Series. If the IP placement requires its IOPLLs to use an HPS Shared GPIO Bank, the fitter may report that no IOPLL IP is available and compilation may fail during the fitter stage. The Low Latency E-Tile 40G Ethernet FPGA IP uses IOPLL IPs configured in Normal Compensation mode. However, the IOPLL resources in an HPS Shared GPIO Bank support Direct Compensation mode only. Consequently, the fitter cannot legally place the IOPLLs in the Low Latency E-tile 40G Ethernet FPGA IP in an HPS Shared GPIO Bank. Resolution To avoid this problem, place the Low Latency E-Tile 40G Ethernet FPGA IP in a supported non-HPS Shared GPIO Bank.Can the F-Tile FGT PMA lane in neutral state of Dynamic Reconfiguration be preserved?
Description Yes, the F-Tile FGT PMA lane can be preserved even after moving to neutral state from normal state by Dynamic Reconfiguration. Resolution While the F-Tile FGT PMA lanes are in the neutral state, users need to keep the TX PMA and RX PMA of the unused lanes in reset until those lanes are reactivated and placed back into operating mode in the future. The performance of those lanes will not be degraded after they are reactivated.Design Assistant CDC-50001, CDC-50011, and CDC-50012 warnings from the F-Tile Dynamic Reconfiguration one-hot profile select paths
Description When compiling designs that use the F-Tile Dynamic Reconfiguration Suite IP, Design Assistant may report CDC-50001, CDC-50011, or CDC-50012 warnings whose source list includes the DR one-hot profile select (dr_ctrl_sip_inst\|dr_profile_1hot_sel_src_sync\|sync[*] or equivalent one_hot_sel_int[*]). CDC-50001 occurs when the one-hot profile select drives generated tile-adapt mux logic. CDC-50011 occurs when synchronized one-hot bits pass through generated profile-selection OR/mux gating with PHY ready or reset_ack level status before an existing destination synchronizer; two aggregate TX paths may also include a level-status reduction AND before that synchronizer. CDC-50012 occurs when the quasi-static one-hot select is added to a cone that also contains a status signal from another source clock, causing Design Assistant to classify the destination synchronizer as driven by multiple domains. It’s safe to ignore these warning. All the three warnings are expected Design Assistant noise, not functional issues. The one-hot selection changes only during the controlled DR sequence, remains stable during normal operation, and the associated status signals are synchronized level signals rather than pulses. Resolution To work around this problem, you can waive these paths in the Design Assistant. There is no plan to fix this problem in the future. It’s safe to ignore these warnings.Why does Nios® V/g experience data corruption when using DTCM?
Description Due to a problem in Quartus® Prime software, data corruption may occur when running a Nios® V/g processor application that interacts with a Tightly-Coupled Memory (TCM). This happens because of a RTL bug in the load-store unit. This problem is affecting Nios® V/g processor in, Quartus® Prime Pro Edition release 25.3.1 and earlier Quartus® Prime Standard Edition release 25.1 and earlier When Nios® V/g processor executes a non-TCM load (i.e. Load from On-Chip Memory or memory-mapped CSR) followed by a Data TCM load, the latter corrupts the former. This causes the non-TCM load to receive incorrect load data. For example, lw rd1,0(non-TCM) lw rd2,0(TCM) Expectation Actual Failure rd1 = load data from address “non-TCM” rd1 = load data from address “TCM” rd2 = load data from address “TCM“ rd2 = load data from address “TCM“ Resolution This problem is fixed in Quartus® Prime Pro Edition 26.1 and is scheduled to be resolved in a future Quartus® Prime Standard Edition release. Additional Information A patch is available to fix this problem. Quartus® Prime Standard Edition Software v25.1 Patch 0.01 Please contact Altera Support for additional support.Why does the Quartus® Prime Pro fitter fail when compiling the Agilex® 5 GTS HDMI IP Clocked Video design example with the HDMI PHY?
Description Due to a problem in the Quartus® Prime Pro Edition Software version 26.1.1, the fitter may fail during placement when compiling the Agilex® 5 GTS HDMI IP design example configured with the Clocked Video interface with the HDMI PHY configuration. The failure occurs while routing a core global signal for the HDMI receive path and reports that no valid lab location can be found near chip coordinates (157, 74). The fitter then exits unsuccessfully. Resolution This problem will be fixed in a future release of the Quartus Prime Pro Edition Software.Why is the LPDDR5 option unavailable in the External Memory Interfaces for HPS IP in Quartus® Prime Pro Edition Software version 26.1.1 for Agilex® 3 SoC FPGA?
Description In Quartus® Prime Pro Edition Software version 26.1.1, the LPDDR5 option is not available in the External Memory Interfaces for HPS IP for Agilex® 3 SoC FPGA device because support for this option has not been enabled for the IP. Resolution A patch is available to resolve this issue in Quartus Prime Pro Edition Software version 26.1.1. To install the fix: Download Patch 1.02 for your operating system. Install Patch 1.02 into your Quartus Prime Pro Edition Software version 26.1.1. The patch files are available below: quartus-26.1.1-1.02-windows.exe quartus-26.1.1-1.02-linux.run After installing the patch, the option LPDDR5 will be available in the External Memory Interfaces for HPS IP for Agilex 3 SoC FPGA device.Does the TOD_MASTER_156_25MHz_P signal on the Agilex® 7 FPGA M-Series require external bias circuitry when AC-coupled?
Description The Agilex® 7 FPGA M-Series 039 production-board design uses the TOD_MASTER_156_25MHz_P signal with AC coupling. There is no information whether this AC-coupled interface requires additional external bias circuitry for correct signal transmission and operation. Resolution The reference implementation shows TOD_MASTER_156_25MHz_P with AC coupling and with external bias circuitry. Follow the implementation shown in the AN 555: True Differential Signaling Termination and Biasing for Agilex® 7 FPGA M-Series, Agilex® 5 FPGAs, and Agilex® 3 FPGAsWhy are Board Test System (BTS) power monitoring readings missing or inaccurate on the Agilex® 5 FPGA E-Series 065B Premium Development Kit?
Description The Board Test System (BTS) does not display power readings for FPGA_VCC_1 and FPGA_VCC_2, and does not report current for VCCO_HVIO when running on the Agilex® 5 FPGA E-Series 065B Premium Development Kit. The issue is observed with BTS software version 1.3.5 and prevents reliable power-estimation analysis. Resolution Update the BTS firmware/software to improve voltage-regulator telemetry and support regulator IOUT, VOUT, and POUT reads through the mailbox interface. Validate the corrected readings for FPGA_VCC_1, FPGA_VCC_2, and VCCO_HVIO across supported board configurations. Additional Information The issue is attributed to a firmware limitation or defect in the BTS voltage-regulator telemetry implementation. Voltage and current values read through I2C may be unstable, inaccurate, or unavailable.Why does the Agilex® 7 FPGA M-Series Development Kit fail configuration with bitstream error 0x0015?
Description When configuring an SOF file on the Agilex® 7 FPGA M-Series Development Kit, the configuration process fails and reports bitstream error subcode 0x0015. Resolution Use Quartus® Programmer version 25.3 or later to program the device. Configuration completes successfully when using Quartus® 25.3, and no special processing or modifications to the generated SOF file are required.
Featured Content
Tags
- troubleshooting10,378 Topics
- fpga dev tools quartus® prime software pro4,326 Topics
- FPGA Dev Tools Quartus II Software3,131 Topics
- stratix® 10 fpgas and socs1,543 Topics
- agilex® 7 fpgas and socs1,524 Topics
- arria® 10 fpgas and socs1,375 Topics
- stratix® v fpgas1,313 Topics
- arria® v fpgas and socs1,227 Topics
- cyclone® v fpgas and socs1,056 Topics
- stratix® iv fpgas643 Topics
