Knowledge Base Article
Why are Board Test System (BTS) power monitoring readings missing or inaccurate on the Agilex® 5 FPGA E-Series 065B Premium Development Kit?
Description
The Board Test System (BTS) does not display power readings for FPGA_VCC_1 and FPGA_VCC_2, and does not report current for VCCO_HVIO when running on the Agilex® 5 FPGA E-Series 065B Premium Development Kit. The issue is observed with BTS software version 1.3.5 and prevents reliable power-estimation analysis.
Resolution
Update the BTS firmware/software to improve voltage-regulator telemetry and support regulator IOUT, VOUT, and POUT reads through the mailbox interface. Validate the corrected readings for FPGA_VCC_1, FPGA_VCC_2, and VCCO_HVIO across supported board configurations.
Additional Information
The issue is attributed to a firmware limitation or defect in the BTS voltage-regulator telemetry implementation. Voltage and current values read through I2C may be unstable, inaccurate, or unavailable.
Updated 2 months ago
Version 3.0
