Knowledge Base Article
Design Assistant CDC-50001, CDC-50011, and CDC-50012 warnings from the F-Tile Dynamic Reconfiguration one-hot profile select paths
Description
When compiling designs that use the F-Tile Dynamic Reconfiguration Suite IP, Design Assistant may report CDC-50001, CDC-50011, or CDC-50012 warnings whose source list includes the DR one-hot profile select (dr_ctrl_sip_inst\|dr_profile_1hot_sel_src_sync\|sync[*] or equivalent one_hot_sel_int[*]).
  • CDC-50001 occurs when the one-hot profile select drives generated tile-adapt mux logic.
  • CDC-50011 occurs when synchronized one-hot bits pass through generated profile-selection OR/mux gating with PHY ready or reset_ack level status before an existing destination synchronizer; two aggregate TX paths may also include a level-status reduction AND before that synchronizer.
  • CDC-50012 occurs when the quasi-static one-hot select is added to a cone that also contains a status signal from another source clock, causing Design Assistant to classify the destination synchronizer as driven by multiple domains.
It’s safe to ignore these warning. All the three warnings are expected Design Assistant noise, not functional issues. The one-hot selection changes only during the controlled DR sequence, remains stable during normal operation, and the associated status signals are synchronized level signals rather than pulses.
Resolution
To work around this problem, you can waive these paths in the Design Assistant.
There is no plan to fix this problem in the future. It’s safe to ignore these warnings.
Updated 2 months ago
Version 2.0
