Recent Content
Internal Error: Sub-system: RTM, File: /quartus/tsm/rtm/rtm_min_cost_flow_retimer.cpp, Line: 3097 Cost-scaling is not supported yet.
Description Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, you may see the this internal error during the Fitter stage. Resolution To work around this problem, disable the Early Retimer by adding this QSF assignment: set_global_assignment -name FITTER_EARLY_RETIMING OFF This problem is scheduled to be fixed in a future version of the Quartus® Prime Pro Edition Software.Why are there intermittent calibration failures in the External Memory Interfaces Agilex® 5 FPGA E-Series IP?
Description Due to a problem in Quartus® Prime Pro Edition Software version 25.3.1 and earlier, you may run into intermittent EMIF calibration failures on LPDDR4 1CHx32, 2-Rank configurations running at 1333 MHz on Agilex® 5 FPGA E Series devices. Resolution To work around this problem, disable cross-rank delay averaging by enabling the following debug flag in the parameter table: DBG_CFG_DISABLE_RANK_AVG_AND_OVR This prevents the firmware from averaging DQS-WR delays across ranks, which eliminates the invalid delay setting that causes the MGN-stage calibration failure. Note: Disabling rank averaging may affect traffic stability in some configurations. A patch is available to fix this problem in Quartus Prime Pro Edition Software version 25.3.1. Download and install the below 1.04 patch. This problem has been fixed beginning with version 26.1 of the Quartus Prime Pro Edition Software.Why are Vectored Interrupt Controller IP and Trace Interface IP for Lauterbach missing from Quartus® Prime Pro software IP Catalog?
Description Due to a problem in the Quartus ® Prime Pro Edition Software version 25.3.1 and 26.1, Vectored Interrupt Controller IP and Trace Interface IP for Lauterbach are missing from IP Catalog. It is due to a bug in the IP Catalog. Refer to Embedded Peripherals IP User Guide - Device Support (PDF) for the Vectored Interrupt Controller IP device support. Refer to Nios® II – Lauterbach Trace32 Debug system for more information about Trace Interface IP for Lauterbach. Resolution A patch is available to fix this problem for the Quartus ® Prime Pro Edition Software version 26.1. Download and install patch 0.11 below. Quartus® Prime Pro Edition Software v26.1 Patch 0.11 This problem is currently scheduled to be resolved in a future release of the Quartus ® Prime Pro Edition Software.Why does Board Support Package (BSP) Editor in Quartus® Prime Pro Embedded Edition fails to generate Nios® V processor BSP project from .vds file?
Description Due to a problem in the Quartus® Prime Pro Embedded Edition Software version 26.1 and 26.1.1, the BSP Editor fails to generate Nios® V processor BSP project from .vds file. This issue is not affecting BSP project generation: From .qsys file using BSP Editor in Quartus® Prime Pro Embedded Edition software, or Using BSP Editor in Quartus® Prime Pro Edition software. This issue is caused by a software bug in the BSP Editor of Quartus® Prime Pro Embedded Edition software. Refer to Nios V Embedded Processor Design Handbook - Recommended Tools from Quartus Prime Installer (PDF) for more information on the difference between Quartus® Prime Pro Edition and Quartus® Prime Pro Embedded Edition software. Resolution To work around this problem in the Quartus® Prime Pro Embedded Edition Software version 26.1 and 26.1.1, apply either one of the workarounds below: Switch from .vds to .qsys file Use BSP Editor in Quartus® Prime Pro Edition software version 26.1 or 26.1.1 This problem is currently scheduled to be resolved in a future release of the Quartus® Prime Pro Embedded Edition Software.Why is Agilex® 5 and Agilex® 3 FPGA External Memory Interfaces (EMIF) IP missing from the BSP Linker when the Nios® V processor Board Support Package is generated?
Description Due to a problem in the Quartus ® Prime Pro Edition starting since software version 24.1, the Agilex ® 5 and Agilex ® 3 FPGA EMIF IP is missing from the BSP Linker when generating the Board Support Package. This might occur for Nios ® V processor designs targeting Agilex 5 FPGA or Agilex 3 FPGA, that uses EMIF IP. This is because Agilex 5 and Agilex 3 FPGA EMIF IP are missing the isMemoryDevice agent information. Refer to Nios® V Processor Software Developer Handbook - Memory-Mapped Slave Information (PDF) for information about isMemoryDevice agent information. Refer to External Memory Interfaces (EMIF) IP User Guide Agilex® 5 FPGAs and SoCs (PDF) for information Agilex ® 5 FPGA EMIF IP. Refer to External Memory Interfaces (EMIF) IP User Guide Agilex® 3 FPGAs and SoCs (PDF) for information Agilex ® 3 FPGA EMIF IP. Resolution To work around this problem in the Quartus ® Prime Pro Edition in all the affected software version, apply either one of the following workarounds: Workaround 1: Manually add isMemoryDevice to the EMIF IP (in Platform Designer only) Select the s*_axi4 signal (mainband AXI4 from fabric to controller) that connects to the Nios ® V processor’s instruction/data manager. Right-click, and click Edit Component Instantiation ... Select s*axi4 and edit the Assignments. Enter new Key as embeddedsw.configuration.isMemoryDevice, and Value as 1. Save the new assignment. Generate a new BSP. Workaround 2: Manually define EMIF IP linker memory device Refer to the Nios V Embedded Processor Design Handbook - Defining Address Span Extender Linker Memory Device. The example demonstrates how to manually define Address Span Extender linker memory device. For this problem, apply the same procedure but on the EMIF IP directly. This problem is currently scheduled to be resolved in a future release of the Quartus ® Prime Pro Edition Software. Related Articles LPDDR4 not available in NIOS® V/g linker script - Agilex® 5 FPGA, Quartus® 26.1 Pro Issue with BSP Creation for Nios® V/m Using LPDDR4 on Agilex® 5 FPGA (Quartus® 24.1 & 24.3.1)Why does the GTS AXI Multichannel DMA IP for PCI Express* IP send Completion Data (CplD) with a length exceeding the Maximum Payload Size (MPS) set?
Description Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, the GTS AXI Multichannel DMA IP for PCI Express* IP sends Completion with Data (CplD) lengths that exceed the negotiated Maximum Payload Size (MPS) set. Resolution Patches are available to fix this problem for the Quartus Prime Pro Edition Software version 26.1 versions. Download and install patch below. Quartus Prime Pro Edition Software v26.1 Patch 0.20 This problem is currently scheduled to be fixed in a future release of the Quartus Prime Pro Edition Software.Why do I see a simulation failure with the F-Tile Multi Channel DMA IP for PCI Express* Design Example using the Quartus® Prime Pro Edition Software version 26.1 ?
Description Due to a problem in the Quartus Prime Pro Edition Software version 26.1, you may encounter simulation errors with the F-Tile Multi Channel DMA IP for PCI Express* Design Example. Synopsys VCS/VCS-MX: Error-[SE] Syntax error Following verilog source has syntax error : "./../..//pcie_ed_sim_tb.v", 2015: token is ')'... Error-[TMENF-IL] Top Module/Entity not found Top module/entity/config "pcie_ed_sim_tb.pcie_ed_sim_tb" is not found in library "PCIE_ED_SIM_TB". Error-[NM] No modules defined No modules defined in current design file(s). Siemens Questasim: ** Error: /mentor/questasim/2025.3/linux64/linux_x86_64/qrun failed. Error in macro ./run_msim_setup.tcl line 52 Cadence Xcelium: xmelab: *E,NOUNIT: Unable to find a unit named 'pcie_ed_sim_tb.pcie_ed_sim_tb' in the libraries. xmsim: *F,NOSNAP: Snapshot 'pcie_ed_sim_tb.pcie_ed_sim_tb' does not exist in the libraries. Aldec Riviera-Pro: Error: VCP2000 .../pcie_ed_sim_tb/pcie_ed_sim_tb/sim/pcie_ed_sim_tb.v : (1951, 6): Syntax error. Unexpected token: ). This problem is attributed to a limitation in the provided simulation testbench within this software release. It is important to note that this behavior is confined to the simulation environment and does not impact the functionality or performance of the design on hardware. Resolution This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition Software.Why does Board Support Package Editor fail to generate embedded peripheral IP drivers when generating BSP FreeRTOS project for Nios® V processor?
Description Due to a problem in the Quartus ® Prime Standard Edition Software version 24.1 and 25.1, the BSP Editor fails to generate embedded peripheral IP drivers, when it is generating BSP FreeRTOS project for Nios ® V processor. This is because the BSP Editor is not enabled to generate those drivers in FreeRTOS. Refer to Embedded Peripherals IP User Guide - Driver Support for the list of embedded peripherals with driver support. Resolution Patches are available to fix this problem for the Quartus ® Prime Standard Edition Software version 24.1 and 25.1 Linux and Windows versions. Download and install patch below. Quartus® Prime Standard Edition Software v24.1 Patch 0.01 Quartus® Prime Standard Edition Software v25.1 Patch 0.01 This problem is currently scheduled to be resolved in a future release of the Quartus ® Prime Standard Edition Software.Why does the quartus_pfg tool hang when generating an encrypted bitstream file?
Description Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1 and earlier, the quartus_pfg tool may hang indefinitely while generating an encrypted bitstream file. This is an intermittent problem. Once it occurs for a specific FPGA bitstream, it will always occur for that bitstream. Resolution A patch is available to fix this problem for the Quartus ® Prime Pro Edition Software version 25.3.1. Download and install patch 1.18 This problem is fixed beginning with version 26.1 of the Quartus® Prime Pro Edition Software.
