Knowledge Base Article
Why do I see a simulation failure with the F-Tile Multi Channel DMA IP for PCI Express* Design Example using the Quartus® Prime Pro Edition Software version 26.1 ?
Description
Due to a problem in the Quartus Prime Pro Edition Software version 26.1, you may encounter simulation errors with the F-Tile Multi Channel DMA IP for PCI Express* Design Example.
Synopsys VCS/VCS-MX:
Error-[SE] Syntax error
Following verilog source has syntax error :
"./../..//pcie_ed_sim_tb.v", 2015: token is ')'...
Error-[TMENF-IL] Top Module/Entity not found
Top module/entity/config "pcie_ed_sim_tb.pcie_ed_sim_tb" is not found in library "PCIE_ED_SIM_TB".
Error-[NM] No modules defined
No modules defined in current design file(s).
Siemens Questasim:
** Error: /mentor/questasim/2025.3/linux64/linux_x86_64/qrun failed.
Error in macro ./run_msim_setup.tcl line 52
Cadence Xcelium:
xmelab: *E,NOUNIT: Unable to find a unit named 'pcie_ed_sim_tb.pcie_ed_sim_tb' in the libraries.
xmsim: *F,NOSNAP: Snapshot 'pcie_ed_sim_tb.pcie_ed_sim_tb' does not exist in the libraries.
Aldec Riviera-Pro:
Error: VCP2000 .../pcie_ed_sim_tb/pcie_ed_sim_tb/sim/pcie_ed_sim_tb.v : (1951, 6): Syntax error. Unexpected token: ).
This problem is attributed to a limitation in the provided simulation testbench within this software release. It is important to note that this behavior is confined to the simulation environment and does not impact the functionality or performance of the design on hardware.
Resolution
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition Software.
Updated 5 months ago
