Knowledge Base Article
Internal Error: Sub-system: RTM, File: /quartus/tsm/rtm/rtm_min_cost_flow_retimer.cpp, Line: 3097 Cost-scaling is not supported yet.
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, you may see the this internal error during the Fitter stage.
Resolution
To work around this problem, disable the Early Retimer by adding this QSF assignment:
set_global_assignment -name FITTER_EARLY_RETIMING OFF
This problem is scheduled to be fixed in a future version of the Quartus® Prime Pro Edition Software.
Updated 4 months ago
