Knug's avatar
Knug
5 years ago
How to properly constrain the PFL for STA
Hi @JohnT_Intel
FPGA_dclk output of the PFL (Parallel Flash Loader). FPGA_dclk is an output of the PFL and gets propagated to my top level wrapper output port. The FPGA_dclk is used normally to configure the FPGA.
How to constrain FPGA_dclk? With an output delay corresponding to the input clock?
I used create_clock command at the input pin (in_clk), the tool should automatically generate the correct FPGA_dclk on the output.
The kit I received for max5 from you specified the following DCLK constraint :
set_output_delay -add_delay -max -clock [get_clocks {clkin_50}] 0.000 [get_ports {fpga_dclk}]
set_output_delay -add_delay -min -clock [get_clocks {clkin_50}] 0.000 [get_ports {fpga_dclk}]
It specified 0.000 output delay.
Is this right? No delay at all on the output DCLK?
I had a warning "Min rise delay is equal to max rise delay", if use 0.000
So I used :
create_clock -name {clk} -period 100.000 -waveform { 0.000 50.000 } [get_ports {in_clk}]
# Create the associated virtual input clock
create_clock -name {clk_virt} -period 100.000 -waveform { 0.000 50.000 }
set_output_delay -clock clk_virt \
-max 0.001 \
[get_ports fpga_dclk]
-min 0.000 \
But is this right ?
Back to my original question. How do I properly constrain DCLK which is currently an output ? Using set_output_delay ? If yes, please comment on the above in bold. What -max (for setup) / -min (for hold) values can I use?
Kevin
  • Knug's avatar
    Knug
    Hi @JohnT_Intel
    That kit constraints file looks wrong wrt the DCLK constraint. Please comment here.
    Wrt the PFL FPGA IP User Guide document this needs to be constrained as a generated clock. I did this.
    Reviewing the rest of my wrapper wrt PFL timing constraints.
    It lists many false paths and set_max_delay ones for input/output asynchronous signals in the PFL IP user Guide.
    If any issues will get back.
    Kevin
    • Knug's avatar
      Knug
      Need to use set_max_delay constraints for the following wrt PFL IP User guide :
      • flash_nce
      • flash_addr
      • flash_data
      • fpga_data
      Cannot figure out best set_max_delay values ? to use . Any help on this will be appreciated.
      # Output delay (flash_addr, flash_nce) = Distributed timing budget - board delay = Timing budget (major) - board delay from PFL to flash
      # Taccess (flash ROM time specification during normal access) = 100ns ? (Table 42 of flash spec tacc ?)
      # Timing budget = [roundup(Taccess_pfl/Tpfl_clk) + 1]*Tpfl_clk - Taccess = [roundup(100ns/100ns + 1]*100ns - Taccess = 200ns - Taccess = 200ns - 100ns? = 100ns?
      set_max_delay -from [get_ports {in_clk}] -to [get_ports flash_nce] ?
      set_max_delay -from [get_ports {in_clk}] -to [get_ports flash_addr[*]] ?
      # Read mode (PFL to Flash ROM)
      # Input delay (flash_data) = Timing budget (minor) - board delay from flash to PFL
      set_max_delay -from [get_ports flash_data[*]] -to [get_ports {in_clk}] ?
      # Delay value determined by the board delay and Tsu/Tdh of the FPGA ?
      set_output_delay -clock clk_virt -max ? [get_ports fpga_data[*]]
      set_output_delay -clock clk_virt -min ? [get_ports fpga_data[*]]
      • Knug's avatar
        Knug
        Hi @JohnT_Intel
        I am getting confused now !
        2 different PFL User Guides with 2 different constraint suggestions! Which one is right ??
        https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
        flash_nce set_false_path
        flash_addr set_false_path
        flash_data Normal read mode:
        set_false_path
        • Burst read mode:
        set_input_delay
        fpga_data set_output_delay
        fpga_dclk set_output_delay
        https://www.intel.com/content/www/us/en/programmable/documentation/sss1411439280066.html
        1.4.2.1. Constraining Clock Signal
        1.4.2.2. Constraining Synchronous input and Output ports
        1.4.2.3. Constraining Asynchronous input and Output ports and Bidirectional Synchronous ports
        1.4.2.4. Summary of PFL Timing constraints
        flash_nce set_max_delay -from pfl_clk -to <port>
        flash_addr set_max_delay -from pfl_clk -to <port>
        flash_data
        • Read mode (PFL to Flash ROM)
          set_max_delay -from <port> to pfl_clk
        • Write mode (Flash ROM to PFL) set_false_path
        fpga_data set_output_delay -clock fpga_dclk <port>
        fpga_dclk
        • Input clock to DCLK ratio = 1 create_generated_clock -source pfl_clk -invert <fpga_dclk port>
    • Knug's avatar
      Knug
      Hi @JohnT_Intel
      That link you sent me lists set_output_delay on the fpga_dclk !
      I noticed another doc that lists the fpga_dclk as a generated clk which I constrained.
      I sent another message with the differences between the 2 docs which was confusing. Did you see this ?
      This lists other PFL constraints too. It states false paths in one of them whereas set_max_delays in the other one. This is confusing. Which one is right?
      • Knug's avatar
        Knug
        Hi @JohnT_Intel
        This is what I was talking about :
        flash_nce
        set_false_path
        flash_addr
        set_false_path
        flash_data
        Normal read mode:
        set_false_path
        • Burst read mode:
        set_input_delay
        fpga_data
        set_output_delay
        fpga_dclk
        set_output_delay
        flash_nce
        flash_addr
        flash_data
        fpga_data
        fpga_dclk
    • Knug's avatar
      Knug
      Hi @JohnT_Intel
      I generated another ticket with that and it was deleted again. It is important to get the constraints right. What is going on here ?
      why there are differences in constraints between the 2 intel docs ??
      How do I send a private message? & why my latest messages get deleted ?
      What is your private email address ?
      Not happy with this matter .
  • JohnT_Altera's avatar
    JohnT_Altera
    I send another email to you so that you can reply to it.
