How to properly constrain the PFL for STA
Hi @JohnT_Intel
That link you sent me lists set_output_delay on the fpga_dclk !
I noticed another doc that lists the fpga_dclk as a generated clk which I constrained.
I sent another message with the differences between the 2 docs which was confusing. Did you see this ?
This lists other PFL constraints too. It states false paths in one of them whereas set_max_delays in the other one. This is confusing. Which one is right?
Hi @JohnT_Intel
This is what I was talking about :
2 different PFL User Guides with 2 different constraint suggestions! Which one is right ??
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
flash_nce |
set_false_path |
flash_addr |
set_false_path |
flash_data |
Normal read mode: |
fpga_data |
set_output_delay |
fpga_dclk |
set_output_delay |
https://www.intel.com/content/www/us/en/programmable/documentation/sss1411439280066.html
1.4.2.1. Constraining Clock Signal
1.4.2.2. Constraining Synchronous input and Output ports
1.4.2.3. Constraining Asynchronous input and Output ports and Bidirectional Synchronous ports
1.4.2.4. Summary of PFL Timing constraints
flash_nce |
set_max_delay -from pfl_clk -to <port> |
flash_addr |
flash_data |
set_max_delay -from <port> to pfl_clk
fpga_data |
set_output_delay -clock fpga_dclk <port> |
fpga_dclk |
