spte's avatar
spte
2 months ago
Problem with alt_2p5g_phy and polarity inversion.
We are using Altera alt_2p5g_phy  with a fixed clock of 2.5Ghz.
We need rx and tx polarity inversion in our set up.
Unfortunately the GUI to set up the phy does not allow to modify the polarity.
From the documents of the phy it is clear that this functionality is available.
Is there a way to enable the inversion?
Thanks in advance for any help.
  • alt_2p5g_phy (1G/2.5G/5G/10G Multirate Ethernet PHY for Stratix 10) does support polarity inversion, and there are a couple of paths to enable it when the GUI doesn't expose the control directly.
    What the IP supports
    The underlying transceiver Native PHY used by this IP supports both static and dynamic polarity inversion, depending on which PCS mode is in use
    Standard PCS supports both static and dynamic polarity inversion. However, the Enhanced PCS only supports the static polarity inversion feature. Stratix 10 · General
    Standard PCS path (static + dynamic)
    If your 2.5G configuration uses the Standard PCS:
    Enable TX polarity inversion via the tx_std_polinv port, which controls polarity inversion of TX parallel data to the PMA. When you turn on this parameter, you also need to turn on the Enable tx_polinv port. Stratix 10 · General
    Enable RX polarity inversion via the rx_std_polinv port, which inverts the polarity of RX parallel data. When you turn on this parameter, you also need to enable the Enable rx_polinv port. Stratix 10 · General
    For dynamic control, to enable receiver polarity inversion in Basic/Custom (Standard PCS), Basic/Custom w/ Rate Match (Standard PCS), and Standard PCS low latency mode, select the Enable RX polarity inversion option and the Enable rx_polinv port option in the Native PHY IP core — this mode adds the rx_polinv port. Stratix 10 · General
    Enhanced PCS path (static only)
    If your configuration uses the Enhanced PCS (common for higher-rate gearbox modes):
    The transceiver Native PHY in Enhanced PCS mode does not have tx_polinv and rx_polinv ports. You can use the Gearbox Enable RX data polarity inversion and Enable TX data polarity inversion settings to implement static polarity inversion. Arria 10 · Transceiver/PHY
    You can implement dynamic polarity inversion by reconfiguring the PHY with different Gearbox Enable RX data polarity inversion and Enable TX data polarity inversion settings. Arria 10 · Transceiver/PHY
    Specifically: to enable TX data polarity inversion when using the Enhanced PCS, select the Enable TX data polarity inversion option in the Gearbox section of the Native PHY IP core. Stratix 10 · General · TX
    To enable RX data polarity inversion when using the Enhanced PCS, select the Enable RX data polarity inversion option in the Gearbox section of the Native PHY IP core. Stratix 10 · General
    • MinzhiWang's avatar
      MinzhiWang
      What's the difference between static and dynamic mode?
      Regard
  • Good day.
    Just wanted to check with you, is your concern has been addressed?
    Feel free to let me know if you have further query. Happy to help.
    Pavee
  • spte's avatar
    spte
    Dear Pavee,
    we could not solve the problem, so we were forced to switch to the "native" PHY and configured the whole thing ourselves. We did this by comparing dedicated settings with the pre-definition of 2.5 Gbit. After that, the native PHY allowed us to change the polarity.
    So our problem has been workaround.
    Cheers,
    Stefan
    • paveetirrasrie_Altera's avatar
      Hello Stefan,
      Glad that you've found  the workaround!!
      If you have a new question, feel free to open a new thread to get the support from Altera experts.
      Thank you.
