shashwatss's avatar
shashwatss
8 hours ago
QPrimePro26.1.1: GTS Ethernet Hard IP Rx-PCS issue
Failure to lock PCS at line rate 25Gbps using GTS Ethernet Hard IP
Expected Outcome: rx_pcs_ready= 1 as soon as link is established
Test-setup: (using Agilex-5E-065A-Premium Dev Kit)
  • Point-A: GTS ETH HARD IP, 25G-1, Bank 4A, SFP-2, No ANLT, No FEC, clock: 805.xxxx, xcvr clk=156.25MHz. Design is as per UG, single-instance, containing an avalon jtag mm for comm
  • Point-B: 25G NIC with suitable vendor locked Xcvr, configured with noFEC, no ANLT, for 25G
Observed:
  • CDR-Lock = ok, Rx_pcs_lock=failed, rx_pcs_aligned=failed, tx_lanes_stable=ok
Is there any known issue for 25G line rate? Thanks
  • I did the exact same setup for 10G line rate. It worked.
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
