How to properly constrain the PFL for STA
Hi @JohnT_Intel
I generated another ticket with that and it was deleted again. It is important to get the constraints right. What is going on here ?
why there are differences in constraints between the 2 intel docs ??
How do I send a private message? & why my latest messages get deleted ?
What is your private email address ?
Not happy with this matter .
Hi @JohnT_Intel
I just sent it as a private message. Did you receive it?
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Did you receive my private message?
Another query here wrt constraints. Included this within the private message too.
Hope I will receive a reply soon because we will have a review on this with my company later on today and I have to let them know.
Neither PFL document listed below lists what constrain to add to the flash_nreset output port of my combined PFL.
I have enabled this extra pin in the PFL IP core & connected it to the reset pin of the flash memory device
Is this pin an Asynchronous output? Can I declare to it ie ‘set_false_path -to flash_nreset’ ?
Kevin
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Seen also JTAG signals not constrained.
Timing STA analysis reported following unconstrained :
- no output delay : altera_reserved_tdo
- no input delays : altera_reserved_tms, altera_reserved_tck & alrera_reserved_tdi
How do we constrain them ?
Well editing the ticket now ...
I tried constraining the above jtag signals using input / output delays BUT still see the other issue I have no_clocks reported which I can see its related to the loader Flash programming IP. They popped out 140 of them when I 'check_timing' using the Timing Analyser. Planning to raise a new ticket on this matter!
Few 'Check Timing' No clock listed below :
altera_parallel_flash_loader_2:parallel_flash_loader_2_0|altera_pfl2_pgm:pgm|custom_jtag_counter:jtag_addr|data_reg[0]
altera_parallel_flash_loader_2:parallel_flash_loader_2_0|altera_pfl2_pgm:pgm|custom_jtag_counter:jtag_addr|data_reg[1]::::
sld_hub:auto_hub|alt_sld_fab_with_jtag_input:\instrumentation_fabric_with_node_gen:fabric_gen_new_way:with_jtag_input_gen:instrumentation_fabric|alt_sld_fab:instrumentation_fabric|alt_sld_fab_alt_sld_fab:alt_sld_fab|alt_sld_fab_alt_sld_fab_sldfabric:sldfabric|sld_jtag_hub:\jtag_hub_gen:real_sld_jtag_hub|irf_reg[1][4]
Many others, 140 in total ...
My top level clock is defined ok. What internal generated clock I require here ?
In the other ticket I will include all warnings seen if I can, or should I send them via private message ?
- Knug5 years ago
Contributor
Did you by the way get my private message ? Received no reply to this question yet.
Don't like sending any private messages that will lead nowhere with no reply to them if the recipient has not received them. Please confirm you received my earlier private emails. Thanks
