How to properly constrain the PFL for STA
Normally, the FPGA_dclk signal is not constrain on the delay. The available constrain is input clk to dclk ratio.
Please refer to Table 8 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Hi @JohnT_Intel
That link you sent me lists set_output_delay on the fpga_dclk !
I noticed another doc that lists the fpga_dclk as a generated clk which I constrained.
I sent another message with the differences between the 2 docs which was confusing. Did you see this ?
This lists other PFL constraints too. It states false paths in one of them whereas set_max_delays in the other one. This is confusing. Which one is right?
- Knug5 years ago
Contributor
Hi @JohnT_Intel
This is what I was talking about :
2 different PFL User Guides with 2 different constraint suggestions! Which one is right ??
flash_nce
set_false_path
flash_addr
set_false_path
flash_data
Normal read mode:
set_false_path
• Burst read mode:
set_input_delayfpga_data
set_output_delay
fpga_dclk
set_output_delay
https://www.intel.com/content/www/us/en/programmable/documentation/sss1411439280066.html
1.4.2.1. Constraining Clock Signal
1.4.2.2. Constraining Synchronous input and Output ports
1.4.2.3. Constraining Asynchronous input and Output ports and Bidirectional Synchronous ports
1.4.2.4. Summary of PFL Timing constraints
flash_nce
set_max_delay -from pfl_clk -to <port>
flash_addr
flash_data
- Read mode (PFL to Flash ROM)
set_max_delay -from <port> to pfl_clk
- Write mode (Flash ROM to PFL) set_false_path
fpga_data
set_output_delay -clock fpga_dclk <port>
fpga_dclk
- Input clock to DCLK ratio = 1 create_generated_clock -source pfl_clk -invert <fpga_dclk port>
- Knug5 years ago
Contributor
Hi @JohnT_Intel
I just re-sent the doc differences and it was deleted by the moderator. Why ?
- Knug5 years ago
Contributor
flash_nce
set_false_path
flash_addr
set_false_path
flash_data
Normal read mode:
set_false_path
• Burst read mode:
set_output_delay
fpga_dclk
set_output_delay
flash_nce
flash_addr
flash_data
fpga_data
fpga_dclk
- Knug5 years ago
Contributor
Hi @JohnT_Intel
I just re-sent again the doc differences and it was deleted again by the moderator. Why ?
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Differences in below constraints between the 2 docs. Which constraints are right ?
flash_nce
flash_addr
flash_data
fpga_data
fpga_dclk
Hope this message is not removed too.
