[PCIE_DESIGN_EXAMPLE][AGILEX7][QUARTUS25.3.0] - failed at elaboration process
I am trying to simulate with questa fe the pcie design example (with pipe mode for external dma controller) based on agilex7 generated with quartus pro 25.3.0 but i am facing these issues when i run this script under "pcie_ed_sim_tb/pcie_ed_sim_tb/sim/mentor" as follow : vsim -do run_msim.tcl
# ** Warning: (vsim-3008) [CNNODP] - Component name (i_pclk__x16_l0) is not on a downward path.
# Time: 0 fs Iteration: 0 Instance: /pcie_ed_sim_tb/dut_pcie_tb_ip/dut_pcie_tb/tile File: ../../../../support_logic/pcie_ed_sim_auto_tiles.sv Line: 34589
# ** Error: (vsim-3043) Unresolved reference to 'i_pclk__x16_l0' in ftile_s20_v0__pcie__tile_0.z1577b.z1577b_inst.i_pclk__x16_l0.
# ** Warning: (vsim-3008) [CNNODP] - Component name (i_pclk__x4_l12) is not on a downward path.
# ** Error: (vsim-3043) Unresolved reference to 'i_pclk__x4_l12' in ftile_s20_v0__pcie__tile_0.z1577b.z1577b_inst.i_pclk__x4_l12.
# ** Warning: (vsim-3008) [CNNODP] - Component name (i_pclk__x4_l4) is not on a downward path.
# ** Error: (vsim-3043) Unresolved reference to 'i_pclk__x4_l4' in ftile_s20_v0__pcie__tile_0.z1577b.z1577b_inst.i_pclk__x4_l4.
# ** Warning: (vsim-3008) [CNNODP] - Component name (i_pclk__x8_l8) is not on a downward path.
# ** Error: (vsim-3043) Unresolved reference to 'i_pclk__x8_l8' in ftile_s20_v0__pcie__tile_0.z1577b.z1577b_inst.i_pclk__x8_l8.
# ** Warning: (vsim-3008) [CNNODP] - Component name (i_rxpipe0__dirfeedback) is not on a downward path.
# ** Error: (vsim-3043) Unresolved reference to 'i_rxpipe0__dirfeedback' in ftile_s20_v0__pcie__tile_0.z1577b.z1577b_inst.i_rxpipe0__dirfeedback.
# ** Warning: (vsim-3008) [CNNODP] - Component name (i_rxpipe0__linkevaluationfeedbackfiguremerit) is not on a downward path.
# ** Error: (vsim-3043) Unresolved reference to 'i_rxpipe0__linkevaluationfeedbackfiguremerit' in ftile_s20_v0__pcie__tile_0.z1577b.z1577b_inst.i_rxpipe0__linkevaluationfeedbackfiguremerit.
I also have followed the Altera recommendations :
Note: Due to a problem in the Quartus® Prime Pro Edition Software version 25.3, you are required to add "-suppress 2732" to USER_DEFINED_COMPILE_OPTIONS and "-suppress 10000 " to USER_DEFINED_ELAB_OPTIONS in the run_msim.tcl simulation script manually for a successful simulation with the Questa simulator.
But i am still facing these above issues.
What can i do ?
Frederic
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
- VenT_Altera
Hi Frederic,
Thanks for reaching out.
The suppress 2732/10000 workaround you applied addresses a separate, known issue with the F-Tile Multi Channel DMA IP simulation in Quartus Prime Pro 25.3 when using Riviera Pro or Siemens Questa*: https://community.altera.com/kb/knowledge-base/why-does-simulation-of-the-f-tile-multi-channel-dma-fpga-ip-for-pci-express-erro/338491
The vsim-3008/vsim-3043 errors you are seeing are not targeted in this workaround.
Could you please let me know if you are using F-Tile MCDMA IP, and which Questa FE simulator version? Additionally, could you disable the PIPE mode in your design example generation if your flow does not strictly require this mode?
Note that, the Table 38. Supported Simulators for F-Tile MCDMA IP in https://docs.altera.com/r/docs/683517/25.3.1/multi-channel-dma-ip-for-pci-express-design-example-user-guide/supported-simulators MCDMA Design Example user guide confirms that the External Descriptor Controller Design Example (Data Mover Only mode) does not support Questa - Altera FPGA Edition and requires the full QuestaSIM instead. Please switch to the full QuestaSIM instead of Questa FE if you are using the F-Tile MCDMA IP.
Ven
- VenT_Altera
Hi Frederic,
Are there any updates on my previous message?
Ven
- FGR1
Hello and thanks Ven for answering to my issue.
Yes i confirm that we are using F-Tile MCDMA IP with Data Mover Only option.
I am using Questa Altera FE edition (associated to the Quartus Pro version 25.3.0).
I will try to remove the PIPE mode by using only serial simulation and will get you back soon.
Is there any chance to get a simulation with the above options (Data Mover Only) with a new quartus pro version ?Regards,
Frederic
- VenT_Altera
Hi Frederic,
Thank you for the update.
The Questa Altera FE edition simulator is unlikely to be supported for simulation of the Data Mover Only - External Descriptor Controller Example Design) in future Quartus version. It is recommended to use the full version of QuestaSim to run the simulation, which is supported in Quartus Prime Pro Edition v25.3.0. When using the full version of QuestaSim, you may enable the PIPE option to accelerate the simulation.
Additionally, the vsim-3008 and vsim-3043 errors you encountered previously with PIPE mode enabled can be resolved by switching to the full version of QuestaSim. Please note that you may also need to apply the suppress 2732/10000 workaround described in the KDB (https://community.altera.com/kb/knowledge-base/why-does-simulation-of-the-f-tile-multi-channel-dma-fpga-ip-for-pci-express-erro/338491) before proceeding with the simulation.
Ven
