is1135's avatar
is1135
1 month ago
Evaluation license for 10Gbps Ethernet MAC
Any help will be much appreciated - I would like to evaluate the 'Low Latency 10Gbps Ethernet MAC (6AF7 0119)', but I can not find the appropriate evaluation license on the self-service-licensing center. Even though 'Intel FPGA IP Evaluation Mode' is enabled I keep getting the 'you do not have a valid license' message in the assembler stage (Quartus Prime Version 25.1.0, the device is an Agilex5).
Thank you!
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
  • umut_arrow's avatar
    umut_arrow
    If you're seeing the 'FPGA IP Evaluation Mode feature is turned on for the following cores' message, maybe check if you have any other IP in the design (besides 6AF7 0119).
    Are you using the reference design? Can you share which device group are you using A or B, I'll try to replicate it on my end.
    https://docs.altera.com/r/docs/813665/26.1.1/low-latency-ethernet-10g-mac-ip-design-example-user-guide-agilex-3-and-agilex-5-fpgas-and-socs/quick-start-guide
    • is1135's avatar
      is1135
      There are other IP's in the design but they are all licensed (6AF7 00E4, signal tap, and 6Af7 FFFF). I am not sure what you mean by device group, the device I am currently using is A5EC013BB23AE6S. The design is not the reference design although it is based on it.
      Thank you
        umut_arrow
        I was asking for the device group (Group A and B devices of Agilex 5 family) to replicate the LL 10G MAC ref design.
        I've tried it in Quartus 26.1., and it compiled without any errors. I can see the 6AF7 0119 IP in the assembler report. Could you please share your assembler report and the exact assembler error with the message numbers.
        Maybe a full clean regeneration & build might help, or trying a different version of Quartus.
