Evaluation license for 10Gbps Ethernet MAC
If you're seeing the 'FPGA IP Evaluation Mode feature is turned on for the following cores' message, maybe check if you have any other IP in the design (besides 6AF7 0119).
Are you using the reference design? Can you share which device group are you using A or B, I'll try to replicate it on my end.
https://docs.altera.com/r/docs/813665/26.1.1/low-latency-ethernet-10g-mac-ip-design-example-user-guide-agilex-3-and-agilex-5-fpgas-and-socs/quick-start-guide
- is11351 month ago
There are other IP's in the design but they are all licensed (6AF7 00E4, signal tap, and 6Af7 FFFF). I am not sure what you mean by device group, the device I am currently using is A5EC013BB23AE6S. The design is not the reference design although it is based on it.
Thank you
- umut_arrow1 month ago
I was asking for the device group (Group A and B devices of Agilex 5 family) to replicate the LL 10G MAC ref design.
I've tried it in Quartus 26.1., and it compiled without any errors. I can see the 6AF7 0119 IP in the assembler report. Could you please share your assembler report and the exact assembler error with the message numbers.Maybe a full clean regeneration & build might help, or trying a different version of Quartus.
- paveetirrasrie_Altera5 hours ago
Good day.
The issue has been fixed in v26.3.1 onwards.
Pavee
