[IP_Compiler for PCIe__Cyclone IV GX] How to start the chaining_dma example
Hi everyone,
I want to use the IP Block IP_Compiler for PCIe, for a FPGA Cyclone 4 GX. Firstly, I want to test that IP block via the automatically generated example chaining_DMA.
I installed Quartus Prime 18.1.0.625 Edition lite (the free one). I generated the IP block via the Megawizard.
I installed and opened Modelsim starter edition 2020.1.
I followed the indication in the starter guide, section 2-12 (page 28 / 372).
But after typing the command runtb.do, I got the error "Error loading design" that blocked the simulation.
Compilation happened successfully with 25 warnings, minor I think : (vcom-1236) Shared variables must be of a protected type.
Has anyone an idea on what to do? Who successfully reached the output of Example 2-1 of the User guide by following the indications of that User guide?
That document is available here:
https://docs.altera.com/v/u/docs/655049/ip-compiler-for-pci-express-user-guide
Thank you in advance for your assistance
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
