Error when simulating F-tile Ethernet example design
When running "run_vcsmx.sh" following set of errors occurs
Just one example
Error-[URMI] Unresolved modules
../ex_200G/sim/../../hardware_test_design/support_logic/eth_f_hw_auto_tiles.sv, 2655
"intfc_m_hdpldadapt_avmm1_mux #(.topology("UX16E400GPTP_XX_DISABLED_XX_DISABLED"), .maib_id(0), .num_ip_on_intfc_00(2), .system_pll_ip_index_on_intfc_00(1), .num_ip_on_intfc_01(2), .system_pll_ip_index_on_intfc_01(1)) z1577b_x0_y0_n0__avmm1_0( .pld_avmm1_busy_real (z1577b_x0_y0_n0__avmm1_0__pld_avmm1_busy_real), .pld_avmm1_clk_rowclk_real (z1577b_x0_y0_n0__avmm1_0__pld_avmm1_clk_rowclk_real), .pld_avmm1_cmdfifo_wr_full_real (z1577b_x0_y0_n0__avmm1_0__pld_avmm1_cmdfifo_wr_full_real), .pld_avmm1_cmdfifo_wr_pfull_real (z1577b_x0_y0_n0__avmm1_0__pld_avmm1_cmdfifo_wr_pfull_real), .pld_avmm1_read_real (z1577b_x0_y0_n0__avmm1_0__pld_avmm1_read_real), .pld_avmm1_readdata_real (z1577b_x0_y0_n0__avmm1_0__pld_avmm1_readdata_real), .pld_avmm1_readdatavalid_rea ... "
Module definition of above instance is not found in the design.
eth_f_hw_auto_tiles.sv is a 36 MB sv-file, making debugging of this quite tedious. I've only followed the design example user guide which states the script should be able to run out of the box.
- paveetirrasrie_Altera
May I know what is your IP configuration?
Kindly share with me the Quartus version and device details. And is the simulation files were generated from example design?
Pavee
Good day to you.
Any update based on my last reply?
Pavee
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
