How to properly constrain the PFL for STA
Could you send to me through private message?
Hi @JohnT_Intel
I generated another ticket with that and it was deleted again. It is important to get the constraints right. What is going on here ?
why there are differences in constraints between the 2 intel docs ??
How do I send a private message? & why my latest messages get deleted ?
What is your private email address ?
Not happy with this matter .
- Knug5 years ago
Contributor
Hi @JohnT_Intel
I just sent it as a private message. Did you receive it?
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Did you receive my private message?
Another query here wrt constraints. Included this within the private message too.
Hope I will receive a reply soon because we will have a review on this with my company later on today and I have to let them know.
Neither PFL document listed below lists what constrain to add to the flash_nreset output port of my combined PFL.
I have enabled this extra pin in the PFL IP core & connected it to the reset pin of the flash memory device
Is this pin an Asynchronous output? Can I declare to it ie ‘set_false_path -to flash_nreset’ ?
Kevin
- Knug5 years ago
Contributor
Hi @JohnT_Intel
Seen also JTAG signals not constrained.
Timing STA analysis reported following unconstrained :
- no output delay : altera_reserved_tdo
- no input delays : altera_reserved_tms, altera_reserved_tck & alrera_reserved_tdi
How do we constrain them ?
Well editing the ticket now ...
I tried constraining the above jtag signals using input / output delays BUT still see the other issue I have no_clocks reported which I can see its related to the loader Flash programming IP. They popped out 140 of them when I 'check_timing' using the Timing Analyser. Planning to raise a new ticket on this matter!
Few 'Check Timing' No clock listed below :
altera_parallel_flash_loader_2:parallel_flash_loader_2_0|altera_pfl2_pgm:pgm|custom_jtag_counter:jtag_addr|data_reg[0]
altera_parallel_flash_loader_2:parallel_flash_loader_2_0|altera_pfl2_pgm:pgm|custom_jtag_counter:jtag_addr|data_reg[1]::::
sld_hub:auto_hub|alt_sld_fab_with_jtag_input:\instrumentation_fabric_with_node_gen:fabric_gen_new_way:with_jtag_input_gen:instrumentation_fabric|alt_sld_fab:instrumentation_fabric|alt_sld_fab_alt_sld_fab:alt_sld_fab|alt_sld_fab_alt_sld_fab_sldfabric:sldfabric|sld_jtag_hub:\jtag_hub_gen:real_sld_jtag_hub|irf_reg[1][4]
Many others, 140 in total ...
My top level clock is defined ok. What internal generated clock I require here ?
In the other ticket I will include all warnings seen if I can, or should I send them via private message ?
