21 years ago
ALTPLL Problem
After changing the ALTCLOCKPLL’s in the standard vhdl example design to ALTPLL’s everything still worked fine. But when I changed the ratio on the e0 output of the controller_pll from 1/1 to 4/5 my program stopped working. It never even reaches the first breakpoint. I’m running the lwip_web_server demo program from the LWIP standalone software on a NIOS II processor. (The hello_world program doesn’t run either)
The clock is running from the onboard 50MHz crystal. The rest of the example hardware is exactly as it is provided, except that I removed the lcd hardware in the SOPC builder.
Does anyone have any suggestion as to why the program would stop responding? Everything compiles and the debugger shows that the thread is running. But it never gets anywhere (The longest I’ve run it was 10min) I intermittently get errors ( undocumented error -1) about the sdram not being readable – not sure why the sdram would be influenced by the controller_pll. It might be some other error. But I mention it for completeness sake.
I've been struggling for about a week with this one and I'm completely out of ideas.
Thanks alot.
Jan Hendrik
