21 years agoALTPLL Problem
After changing the ALTCLOCKPLL’s in the standard vhdl example design to ALTPLL’s everything still worked fine. But when I changed the ratio on the e0 output of the controller_pll from 1/1 to 4/5 my p...
21 years agoHi NiosIIuser,
No, I only changed the e0 connector_pll ratio. But the cpu clock is attaced to the c0 connector_pll output that still has a 1/1 ratio. Doesn't that meen that c0 output is still 50Mhz while the e0 output is 40MHz ? The sdram_pll is still c0 ratio 1/1 e0 ratio 1/1 which would make the both 50MHz, right? Here are my settings. If I have to change them to what do I change them to keep the right phazes for each hardware component? -- revering to the sdram phase delay. sdram_pll: inclk0 frequency: 50.000 MHz Operation Mode: Normal Clk___Ratio___Ph_(dg)___TD_(ns)___DC_(%) c0 ___1/1____ 0.00______0.00______50.00 ------- should be 50Mhz clock e0___1/1____ -63.00____0.00______50.00 ------- should be 50Mhz clock delayed by -3.5 ns to compensate for signal delay to sdram connector_pll: inclk0 frequency: 50.000 MHz Operation Mode: Normal Clk___Ratio___Ph_(dg)___TD_(ns)___DC_(%) c0 ___1/1____ 0.00______0.00______50.00 ------- should be 50Mhz clock e0___4/5____ 0.00______0.00______50.00 ------- should be 40Mhz clock that goes to PLD_CLKOUT Is this right or should I change it. Thanks again.
