17 years ago
SRAM interface timing discrepancy from Quartus-II 7.0 and 9.0
I have a design which contains an SRAM interface with the default PLL phase shift, -4.8ns for this SRAM. It was compiled by Quartus-II 7.0 and it works perfectly on my target board with an EP2C20F484C7. Recently, I updated the design software to Quartus-II 9.0 SP1, the same design was compiled successfully. However, the design didn't work on my target board. The NIOS-II didn't start. The debugger stopped before my application code. It took a while for me to find what causes the problem. I found that it was caused by SRAM interface timing from Quartus-II 9.0 SP1. When I reduce the PLL phase shift to -4.5ns, it starts to work while in Quartus-II 7.0, it can work when the PLL phase shift is set upto -6.7ns. Although this problem has been resolved, I want to know if there are other discrepancies or any implications. Many thanks.
