Quartus 25.1std | Signal Tap Crash
I would like to ask for help. I'm programming a Cyclone V with Quartus 21.1 Standard edition. I'm trying to implement signal tap to my design. My stp file is able to compile with the .sof/.pof generation but when I go to acquire data Quartus by clicking "run analysis" keeps on crashing. I get the following problem.
Problem Details
Error:
*** Fatal Error: Uncaught C++ Exception Module: quartus.exe Stack Trace: 0xc41c9: RaiseException + 0x89 (KERNELBASE) 0x671f: _CxxThrowException + 0x8f (VCRUNTIME140) 0x3b551: std::_Xout_of_range + 0x21 (MSVCP140) 0x56ef: std::_String_val<std::_Simple_types<char> >::_Xran + 0xf (sld_chi) 0x9682: CHI_CONTROL_NODE_STP_V6::construct_load_data + 0x2f2 (sld_chi) 0xe6be: CHI_CONTROL_NODE_STP_V6::initialize_setup_offload_cache + 0x4ee (sld_chi) 0xdac4: CHI_CONTROL_NODE_STP_V6::init_acquisition + 0x174 (sld_chi) 0x1182c: CHI_CONTROL_NODE_STP_V6::start + 0x22c (sld_chi) 0x58e5: CHI_CONTROL_NODE_STP::acquisition_thread_proc + 0x35 (sld_chi) 0x13b18: msg_thread_wrapper + 0x78 (CCL_MSG) 0x15f13: mem_thread_wrapper + 0x73 (ccl_mem) 0x2773: thr_thread_begin + 0x33 (ccl_thr) 0x2cd86: BaseThreadInitThunk + 0x16 (KERNEL32) 0xacaeb: RtlUserThreadStart + 0x2b (ntdll)
End-trace
Quartus Prime Version 25.1std.0 Build 1129 10/21/2025 SC Standard Edition
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 25.1std.0
Build: 1129
Edition: Standard Edition
I can't seem to get to the bottom of why this is happening. I don't believe there are any Quartus patches for signal tap for version 25.1std.0
If someone could help that would be greatly appreciated.
- RyanNguyen
New Member
Also I'm running windows 11. I'm not sure why the error logs shows I'm on windows 10.
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
