programmable logic device
471 TopicsCyclone IV GX (EP4CGX30CF23C7) Flash Issue
Dear Altera Support Team, We are currently using the Cyclone IV GX FPGA (EP4CGX30CF23C7) on our production board, configured via Active Serial (AS) mode using a 16Mb SPI Flash. We are encountering functional failure and Checksum mismatch when attempting to migrate our flash memory from the old part to a new part. Could you please help verify if this new part is officially supported or if there are any known configuration issues? Flash Comparison & Details: Original Part (Working): Macronix MX25L1606EM2I-12G Size : 200040h Checksum: 13F8B518h New Part (Failing / Function Abnormal): Macronix MX25V1606FM2I03 Size: 200000h Checksum: 13F87558h Observed Symptoms: After programming the new MX25V1606FM2I03, the FPGA fails to configure successfully (AS configuration error / LED status fails to initialize). We noticed a discrepancy in the binary size (200040h vs 200000h) and Checksum between the two programming files generated or read back. Questions for AE: Is the MX25V1606FM2I03 fully compatible with Cyclone IV GX Active Serial (AS) configuration requirements? (Considering it's a 2.5V/3V or different revision series from the 'L' version). Why does the generated image size show an extra 40h offset (200040h) on the original MX25L1606E, and how does this affect the Cyclone IV configuration loader? Could the slight electrical specification or command set difference (e.g., Read/Write ID or timing parameters) between the MX25L1606E and MX25V1606FM2I03 cause the FPGA configuration failure? Any guidance or documentation references would be greatly appreciated. Thank you for your support!137Views0likes7CommentsClarification on BGA Ball/Pin Pattern for Altera FPGA Devices
Hi Team, We are created PCB footprints for the following Altera FPGA devices: AGIB022R31A2E2VCNL – BGA-3184 A3CY050BB18BE7S – BGA-538 A3CY135BB23CE7S – BGA-931 While reviewing the manufacturer package drawings and creating the footprints, we observed that the ball/pin pattern uses different pad arrangements and the pitch between the pins/balls is not uniform in some areas. Could you please clarify whether there is a specific design or manufacturing reason for using these different ball/pin patterns and pitch arrangements?29Views0likes2CommentsArria 10 Transceiver IBIS-AMI Model: Latest Version (Rev 2.0, July 2016 vs. October 2016)
Title: Arria 10 Transceiver IBIS-AMI Model: Latest Version (Rev 2.0, July 2016 vs. October 2016) Hello, We have the Arria 10 GX/GT Transceiver IBIS-AMI model. According to the IBIS-AMI user guide included with the model, its version is "Rev 2.0, July 30, 2016". However, "Table 2b. Device Models for Transceiver Pins" on the following page lists the latest model as: - Model Revision: 2.0 - Model Last Updated: 10/2016 https://www.altera.com/support/support-resources/download/board-layout-test/hspice.html Could you please answer the following questions? 1. Are there two different releases of Rev 2.0 (July 2016 and October 2016)? 2. If so, what are the differences between the July and October releases? 3. We plan to run SI simulations of the transceivers for the 10AX027H3F34E2SG soon. Is it acceptable to use the July 2016 release for our SI analysis? Thank you for your support. Best regards,40Views0likes2CommentsCXL Type 2 DMA/Mem Access Triggers CPU MCE on Sapphire Rapids
We are using an Intel DK-DEV-AGI027-RA-B board (programmed with CXL Type 2 IP) on a 2-socket Intel Xeon Platinum 8468V (Sapphire Rapids) platform. The card is in socket 1, behind root port 0000:a7:01.0 (8086:352a) and CXL host bridge ACPI0016:07, and is enumerated as 0000:a8:00.0 / 0000:a8:00.1. When I simultaneously access the Type 2 device memory and cause the device to access host memory via DMA, the host logs a CPU2 “uncorrectable machine check exception” and hangs. The fault record contains only the CPU-side IEH (8086:0b23, BDF a7:00.4) and one PCIe:(0XA7:0X00.0X04) record. There is no OS AER event because AER is firmware-first (OsNativeAerSupport is disabled). The boot console also shows “Cannot find PCIe Capability in CXL 1.1 upstream RCRB, cannot set ASPM” and the repeated message “LocateExtCapability () Incorrect DS link encountered on A800FFC pci config space.” Could you please advise why this occurs and how to decode the IEH/eMCA records and capture the exact AER TLP type (config vs MMIO vs CXL.cache/DMA)?70Views0likes3CommentsMAX 10 DA vs DD devices, can the same programming file be used?
We are considering using both DA and DD variants of the MAX 10, for example 10M50DAF484 and 10M50DDF484. According to the device ordering information, the DD option adds Flash Access Control compared with the DA option. Could you please clarify the following: Can the same Quartus-generated .pof programming file be used to program both the DA and DD devices, assuming the density, package, speed grade, and FPGA design are otherwise identical? Or must the Quartus project target the exact DA/DD device and generate a separate .pof for each OPN? If separate files are required, what is different in the generated programming data? Does the answer change if we are not using the DD Flash Access Control feature? Our goal is to determine whether DA and DD devices can be used interchangeably in production without maintaining separate FPGA programming files. Thank youSolved45Views0likes2CommentsRequest for Part status and Datasheet
Dear Team, Hope you are doing well. Could you please advise if part no EP3C120F780I7SZ is valid and Active from ALTERA. I am unable to determine option suffix SZ indicate as it is not listed in any of the documentation. Also can you please advise if part no's EP3C120F780I7N and EP3C120F780I7 are Active and available. in case these are Discontinued. Please share EOL notice. Regards, Santosh342Views0likes4CommentsPossible Incorrect Clock Label in Cyclone IV Handbook Figure 7-8 (DQ/DQS)
Hello Altera Support Team, While studying the DDR output architecture of Cyclone IV devices, I noticed a possible inconsistency in the official documentation. **Document information:** - Document: Cyclone IV Device Handbook, Volume 1 - Document Number: CYIV-5V1-2.2 - Chapter 7: External Memory Interfaces in Cyclone IV Devices - Revision: March 2016 **1. Figure 7-8: Cyclone IV Dedicated Write DDIO** In Figure 7-8 (page 7-14), the clock input to the DDIO registers is labeled **"-90° Shifted Clock"**, while the output is labeled **"DQ or DQS"**. This appears to imply that the same phase-shifted clock arrangement applies to both DQ and DQS output paths. **2. Figure 7-9: Extending the OE Disable by Half a Clock Cycle for a Write Transaction** However, Figure 7-9 (page 7-15) explicitly identifies two different output clocks: - System Clock: outclock for DQS - Write Clock: outclock for DQ, shifted by -90° relative to the System Clock Furthermore, the PLL section on page 7-15 states that the system clock generates the DQS write signals, while the -90° shifted write clock generates the DQ signals during write operations. **3. My question** These descriptions appear inconsistent with the clock labeling in Figure 7-8. Could you please clarify: 1. Is Figure 7-8 intended to represent a generic DDIO structure, with the "-90° Shifted Clock" label applying specifically to the DQ path? 2. For the DQS output path, are its DDIO data registers and output-enable registers clocked by the unshifted System Clock, as suggested by Figure 7-9? 3. If so, should the clock label in Figure 7-8 be corrected or clarified to distinguish the DQ and DQS paths? I would appreciate confirmation of the actual hardware clock connections and whether this is a documentation error. Thank you for your time and assistance.115Views0likes6Comments
