17 years agoSRAM interface timing discrepancy from Quartus-II 7.0 and 9.0
I have a design which contains an SRAM interface with the default PLL phase shift, -4.8ns for this SRAM. It was compiled by Quartus-II 7.0 and it works perfectly on my target board with an EP2C20F484...
17 years agowell, i had recalculated _ALL_ timings and also verified them with a LeCroy Scope in real life target. as nearly all fpga's here rely on the same sources and use the same software binary, i had to do this a dozend times.
also check your quartus settings. for the sdram if here, i rechecked that fast input outregisters and other settings are as needed. and i guess you have checked the pin output current settings to prevent over and undershots. thats why i checked it with a very fast scope
