mario's avatar
mario
1 month ago
Agilex 5 RCOMP_GTS connection change and its effect on HVIO input pins
Hi There,
In the Pin Connection Guidelines below, the connection method for the RCOMP_GTS pins has been changed.
https://docs.altera.com/r/docs/813266/current/pin-connection-guidelines/example-1-agilextm-5-devices-with-speed-and-power-grade-1v-2v-2e-and-3v
Related KDB: Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration? | Altera Community - 353565
We have two questions.
  1. Is this change due to a change in the device itself (silicon or specification)? Or was only the document updated, with no change to the device?
  2. Why do the HVIO input pins stop working when RCOMP_GTS is floating? We thought the HVIO bank and the GTS transceiver bank were not related.
Kindly advise.
Thank you.
  • mario's avatar
    mario
    Thank you for the explanation. I understand that this is a documentation update rather than a silicon change, and that RCOMP_GTS must be connected as specified when the corresponding GTS power supplies are powered.
    However, my second question concerns the underlying internal mechanism, rather than the failure conditions or workaround.
    Could you please clarify the following?
    1. What internal architectural dependency exists between the GTS transceiver bank and the adjacent HVIO bank?
    2. Even when no transceiver is instantiated in the design, why does leaving RCOMP_GTS floating prevent the HVIO input or bidirectional pins from being configured correctly?
    3. Why is the impact limited to the adjacent HVIO bank?
    If detailed circuit information cannot be disclosed, a high-level explanation would be sufficient.
    Thank you.
    • AqidAyman_Altera's avatar
      AqidAyman_Altera
      Hi Mario,
      Altera does not publish a detailed internal circuit description of the GTS-to-HVIO path. At the level we can share publicly: this is a product architecture requirement on Agilex 5 and Agilex 3 devices with GTS. When RCOMP_GTS on a side is left floating and that side's GTS supplies are powered, the HVIO pins in the HVIO bank adjacent to that GTS bank are not configured correctly during device configuration. The device still configures and enters user mode, but those HVIO pins (input or bidirectional) can look stuck high or otherwise non-functional.
      That is also why:
      - Instantiating no transceiver in the Quartus design does not avoid the issue. The board power / RCOMP connection condition is what matters.
      - The impact is limited to the HVIO bank adjacent to the affected GTS side, as stated in the Knowledge Base article.
      • mario's avatar
        mario
        Thank you for your reply.
        I understand that the detailed internal circuit architecture is not publicly available.
        We are planning to follow the KDB guidance and connect a 499 Ω resistor between the RCOMP_GTS P and N pins.
        Could you please also clarify the following two points?
        1. What is the maximum voltage across this resistor? We do not expect an issue with its voltage rating or derating, but would like to confirm this as a precaution.
        2. Are there any constraints or recommendations regarding the resistor placement or the trace length between the RCOMP_GTS pins and the resistor?
        Thank you.
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Great questions — let me address both directly.
    Question 1: Is this a silicon/device change or just a documentation update?
    This is a documentation/guideline update only — there is no change to the silicon or the device itself. Altera issued Customer Advisory ADV0057 to inform customers of the updated Pin Connection Guidelines for Agilex 5 and Agilex 3 device families. Importantly, this notification is explicitly stated to not be a device change — there are no changes to the products. ADV0057 Agilex® 3 and Agilex® 5 FPGA Devices Pin Connection Guidelines Update
    The specific update in the Agilex 5 PCG was to Section 1.3.2 (GTS Transceiver Pins): the Connection Guidelines for the RCOMP_GTS pin were clarified to state that you should leave these floating only if the entire side of the GTS transceiver power supply pins (VCCEHT_GTS and VCCERT_GTS) are tied to GND. ADV0057 Agilex® 3 and Agilex® 5 FPGA Devices Pin Connection Guidelines Update
    The authoritative connection requirement itself is: The RCOMP_GTS pins serve as external biasing resistors for GTS. Each RCOMP_GTS[L1,R4][A,B,C,D,E,F]_P pin must be connected with a 499-Ω resistor (±0.1%) to the corresponding RCOMP_GTS[L1,R4][A,B,C,D,E,F]_N pin. In the PCB layout, the trace from this pin to the resistor must be routed to avoid any aggressor signals. These pins may be left floating only if the entire side of the GTS transceiver power supply pins (VCCEHT_GTS and VCCERT_GTS) are tied to GND. Pin Connection Guidelines
    Question 2: Why do HVIO input pins stop working when RCOMP_GTS is floating?
    Your intuition that HVIO and GTS transceiver banks are separate is reasonable, but there is a specific interaction at the hardware level. In Agilex 5 (and Agilex 3) devices that include transceivers, if the board connects power to the GTS transceiver bank but leaves the RCOMP pin unconnected — regardless of whether the design actually instantiates a transceiver — HVIO pins configured as input or bidirectional in a specific HVIO bank may fail to function after device configuration. The pins can appear stuck at high, not respond to user logic, or fail to transition to the expected I/O behavior. This does not affect the device configuration process and the device does enter user mode. Critically, the issue specifically affects the HVIO bank adjacent to the GTS transceiver bank, and is related to specific power and pin connection conditions during board design. Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration?
    There is also a related Quartus Prime Pro software-side manifestation of this issue: due to a problem in Quartus Prime Pro Edition Software versions 23.4.0 Patch 009, 23.4.1, and 24.1, the HVIO input pin may be stuck at high in Agilex 5 designs that do not include a transceiver and leave the RCOMP pin unconnected when the HVIO pin is configured as input or bidirectional. The device configuration process itself is not affected. A patch is available for version 24.1 (Windows: quartus-24.1-0.15fw-windows.exe; Linux: quartus-24.1-0.15fw-linux.run). Why does the high-voltage I/O (HVIO) input pin stuck at high in Agilex™ 5 FPGA devices?
    Bottom line for your board design: Always connect the RCOMP_GTS P/N pins with the 499-Ω (±0.1%) resistor whenever the GTS transceiver power rails (VCCEHT_GTS / VCCERT_GTS) are powered — even if you are not using transceivers in your design. Omitting this connection while the GTS power rails are active is what triggers the HVIO failure in the adjacent bank.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
