Agilex 5 RCOMP_GTS connection change and its effect on HVIO input pins
Thank you for the explanation. I understand that this is a documentation update rather than a silicon change, and that RCOMP_GTS must be connected as specified when the corresponding GTS power supplies are powered.
However, my second question concerns the underlying internal mechanism, rather than the failure conditions or workaround.
Could you please clarify the following?
- What internal architectural dependency exists between the GTS transceiver bank and the adjacent HVIO bank?
- Even when no transceiver is instantiated in the design, why does leaving RCOMP_GTS floating prevent the HVIO input or bidirectional pins from being configured correctly?
- Why is the impact limited to the adjacent HVIO bank?
If detailed circuit information cannot be disclosed, a high-level explanation would be sufficient.
Thank you.
- AqidAyman_Altera1 month ago
Hi Mario,
Altera does not publish a detailed internal circuit description of the GTS-to-HVIO path. At the level we can share publicly: this is a product architecture requirement on Agilex 5 and Agilex 3 devices with GTS. When RCOMP_GTS on a side is left floating and that side's GTS supplies are powered, the HVIO pins in the HVIO bank adjacent to that GTS bank are not configured correctly during device configuration. The device still configures and enters user mode, but those HVIO pins (input or bidirectional) can look stuck high or otherwise non-functional.
That is also why:
- Instantiating no transceiver in the Quartus design does not avoid the issue. The board power / RCOMP connection condition is what matters.
- The impact is limited to the HVIO bank adjacent to the affected GTS side, as stated in the Knowledge Base article.
- mario1 month ago
Thank you for your reply.
I understand that the detailed internal circuit architecture is not publicly available.
We are planning to follow the KDB guidance and connect a 499 Ω resistor between the RCOMP_GTS P and N pins.Could you please also clarify the following two points?
- What is the maximum voltage across this resistor? We do not expect an issue with its voltage rating or derating, but would like to confirm this as a precaution.
- Are there any constraints or recommendations regarding the resistor placement or the trace length between the RCOMP_GTS pins and the resistor?
Thank you.
Hi Mario,
Thank you for confirming the plan. Connecting the 499 Ohm resistor between RCOMP_GTS_P and RCOMP_GTS_N is the correct fix whenever the GTS supplies on that side are powered.
1. Maximum voltage across the resistor
Altera does not publish a maximum voltage specification for the RCOMP_GTS resistor. The only electrical requirement in the Pin Connection Guidelines is the resistor value: 499 Ohm with +/-0.1% tolerance between each RCOMP_GTS[L1,R4][A-F]_P pin and its corresponding _N pin. RCOMP_GTS is a calibration reference inside the GTS bank, so the voltage across the resistor is low and comes from the GTS bank supplies, not from any external source. A standard thin-film 0.1% resistor in a common SMD package is far above the rating needed here. The tolerance is the parameter to control, because the GTS calibration depends on the resistor value. Please do not substitute a 1% part.
2. Placement and trace length
The Pin Connection Guidelines give one layout requirement: the trace from the RCOMP_GTS pin to the resistor must be routed so that it avoids any aggressor signals. Altera does not publish a maximum trace length or a maximum distance from the ball to the resistor for GTS RCOMP. As general good practice for a calibration reference, we suggest:
- Place the resistor close to the RCOMP_GTS_P/N balls, for example on the bottom side under the BGA or right at the breakout.
- Keep the P and N traces short and route them as a tight loop.
- Keep them away from high-speed transceiver lanes, clocks, and switching regulator nodes.
However, please be noted that this is just a general suggestion and not official Altera's recommendations.
Reference: Pin Connection Guidelines: Agilex 5 FPGAs and SoCs, GTS Transceiver Pins table
https://docs.altera.com/r/docs/813266/current/pin-connection-guidelines
Aqid
