generic io
251 TopicsPossible Incorrect Clock Label in Cyclone IV Handbook Figure 7-8 (DQ/DQS)
Hello Altera Support Team, While studying the DDR output architecture of Cyclone IV devices, I noticed a possible inconsistency in the official documentation. **Document information:** - Document: Cyclone IV Device Handbook, Volume 1 - Document Number: CYIV-5V1-2.2 - Chapter 7: External Memory Interfaces in Cyclone IV Devices - Revision: March 2016 **1. Figure 7-8: Cyclone IV Dedicated Write DDIO** In Figure 7-8 (page 7-14), the clock input to the DDIO registers is labeled **"-90° Shifted Clock"**, while the output is labeled **"DQ or DQS"**. This appears to imply that the same phase-shifted clock arrangement applies to both DQ and DQS output paths. **2. Figure 7-9: Extending the OE Disable by Half a Clock Cycle for a Write Transaction** However, Figure 7-9 (page 7-15) explicitly identifies two different output clocks: - System Clock: outclock for DQS - Write Clock: outclock for DQ, shifted by -90° relative to the System Clock Furthermore, the PLL section on page 7-15 states that the system clock generates the DQS write signals, while the -90° shifted write clock generates the DQ signals during write operations. **3. My question** These descriptions appear inconsistent with the clock labeling in Figure 7-8. Could you please clarify: 1. Is Figure 7-8 intended to represent a generic DDIO structure, with the "-90° Shifted Clock" label applying specifically to the DQ path? 2. For the DQS output path, are its DDIO data registers and output-enable registers clocked by the unshifted System Clock, as suggested by Figure 7-9? 3. If so, should the clock label in Figure 7-8 be corrected or clarified to distinguish the DQ and DQS paths? I would appreciate confirmation of the actual hardware clock connections and whether this is a documentation error. Thank you for your time and assistance.115Views0likes6CommentsOne simple issue about I/O input and output
There are one MCU ( for example ARM chip) and Cyclone 10 GX device on our board. The MCU drives one normal single-ended port to FPGA's single-ended I/O pin. My question is whether logic inside FPGA can forward this signal output thru LVDS pair? For this LVDS pair will be used to drive outside pulse distributor chip. Which has LVDS standard as input port. Best Regard62Views0likes2CommentsMissing AC characteristsics in A5E data sheet !
With reference to this link : https://docs.altera.com/r/docs/813918/current/agilex-5-fpgas-and-socs-device-data-sheet/switching-characteristics where are these numbers ? I would like the switching performance of the 1.8V Agilex5 I/O. Is there any AC/DC performance specification anywhere for the HVIO ? -glenSolved157Views0likes7CommentsUpdated .brd file for Stratix 10 GX dev kit
Referencing this post: EK-10M08E144 PCB .brd file corrupted | Altera Community - 302242 The .brd file that comes in the documentation at: https://www.altera.com/products/devkit/po-3028/stratix-10-gx-signal-integrity-development-kit-h-tile ...was done in Allegro, prior to version 16.6. The only available Allegro viewer gives an error because it was done prior to version 16.6, and you need the DB Doctor utility to update the file. The only way to get the DB Doctor utility is to install Allegro. If I had Allegro...I would not be installing the Allegro viewer. Altera: As mentioned in the post above (well over a year ago), it would make sense for you to update your files so customers can view the board of their $10K+ development board. How do we make that happen? Thanks!585Views0likes5CommentsRequest for Technical Meeting – FPGA Selection, ADRV9029 Integration, and Procurement Support
Dear Intel FPGA Team, Greetings from PARAS Defence and Space Technologies. We are currently evaluating FPGA solutions for our C-band SATCOM terminal project. Our key application requirements are as follows: RF frequency range: 4.4–4.95 GHz • Instantaneous RX bandwidth: 16 MHz • RF channels: 4 RX and 4 TX • Interface: JESD204B/C between the RF transceiver and FPGA • Application: Ground-based SATCOM terminal for tracking a moving aircraft We are considering the Intel Arria 10 FPGA family as a potential platform and have reviewed the available reference design for the ADRV9029 Sub-6 GHz evaluation board with Arria 10 FPGA. To clarify the technical feasibility and plan our development and procurement activities, we would like to arrange a meeting with your FPGA technical and sales teams to discuss the following topics. FPGA Selection and Compatibility Recommendation of a suitable Arria 10 or other Intel FPGA family and specific part number for our application, considering JESD interface requirements, FPGA resources, transceiver capabilities, and future scalability. ADRV9029 JESD204 Integration Confirmation of the supported JESD204B/C configurations, available transceiver lanes, achievable lane rates, and relevant FPGA IP requirements for interfacing with the ADRV9029. Reference Design and Porting Support Guidance on the available ADRV9029–Arria 10 reference design, required hardware platform, design files, software dependencies, and the feasibility of adapting the reference design to our intended FPGA platform. Development Tools and Technical Support Information on the required Intel Quartus Prime software edition, JESD204 IP licensing, simulation resources, design examples, and technical support available during FPGA development. Evaluation Hardware Recommendations for a suitable FPGA development kit or evaluation platform for initial ADRV9029 integration, including availability, compatibility, and procurement options. Product Presentation A technical presentation covering relevant FPGA families, high-speed transceiver capabilities, JESD204 interface solutions, design resources, and application examples suitable for RF and SATCOM systems. Procurement and Commercial Discussion Indicative pricing, product availability, lead times, development kit costs, and long-term supply considerations for prototype development and production. We would appreciate the opportunity to discuss these requirements with your technical specialists and sales representatives at a mutually convenient date and time. Please let us know your availability and whether any additional technical information is required from our side before the meeting. Thank you for your support. We look forward to your recommendations and to working with your team to identify a suitable FPGA solution for our project.93Views0likes2CommentsAgilex 5 RCOMP_GTS connection change and its effect on HVIO input pins
Hi There, In the Pin Connection Guidelines below, the connection method for the RCOMP_GTS pins has been changed. https://docs.altera.com/r/docs/813266/current/pin-connection-guidelines/example-1-agilextm-5-devices-with-speed-and-power-grade-1v-2v-2e-and-3v Related KDB: Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration? | Altera Community - 353565 We have two questions. Is this change due to a change in the device itself (silicon or specification)? Or was only the document updated, with no change to the device? Why do the HVIO input pins stop working when RCOMP_GTS is floating? We thought the HVIO bank and the GTS transceiver bank were not related. Kindly advise. Thank you.173Views0likes5CommentsCyclone IV drop in replacement confirmations
Dear Altera, If the BANK VCCIO is 1.8V and the same package but with different LE # FPGA is drop in replace. Where the original pin is a VCCA while different LE size same pin is a IO. With 1.8V on VCCIO and input fixed to VCCA aka 2.5V do this introduce any issue? As we can see the datasheet mentioned the DC input accept 3.6 or below. -> Table 1–4. Recommended Operating Conditions for Cyclone IV GX Devices (Part 2 of 2) So the C4 device have a protection forward diode to clamp the voltage when IO is set to input? As long as that pin is fixed to input state do this condition function properly? Thanks, BrianSolved373Views0likes13Comments3.3 V Connection to ADC_VREF When Replacing a MAX 10 SC Device with an SA Device
We are considering replacing a 10M08SCU169C8G with a 10M08SAU169C8G and would like to avoid a PCB revision if possible. On the existing PCB, pin D3 (VCCA3) of the SC device is connected to 3.3 V. When the SA device is installed, the same pin becomes ADC_VREF, so ADC_VREF would remain connected to 3.3 V. We do not intend to use the ADC or an external ADC reference. We understand that the MAX 10 Pin Connection Guidelines specify that ADC_VREF should be left unconnected (NC) when an external reference is not used. Under these conditions, would leaving ADC_VREF connected to 3.3 V affect device operation or reliability? Is a PCB revision to leave pin D3 unconnected required in order to use the SA device? Thank you for your guidance.113Views0likes3CommentsSchematics/layout for TerasIC SoCKit rev. D with Cyclone V
Greetings! I am working with an ALTERA/TerasIC SoCKit development board for Cyclone V. I've downloaded the "SoCKit CD-ROM ( rev. D Hardware )" archive from www.terasic.com.tw, but it does not contain schematics or PCB layout files. What I want to do is access ~8 GPIO pins on the board, but it does not have a GPIO header. So I can either solder to the mysterious "AD-DA HDR" connector plus some LEDs/switches, or connect to one of the 3 groups of pins on the wide HSMC (one has 20 differential pairs, the other two have 60 pins each) using a Samtek connector. To do that, I need to know how the pins on the SoCKit's PCB connectors map to the 5CSXFC6D6F31C6 IC's pads. BTW, I really appreciate the board having pads for an Altera JTAG connector pads: EthernetBlaster can be used with it! --A.166Views0likes6Comments
