Giorgi_Kvernadze's avatar
Giorgi_Kvernadze
5 months ago
Bidirectional differential port on MAX10
I want to implement a bidirectional differential port on a MAX10 10M02SCU324C8G
I first tried to do it on my own and then tried to do it with the GPIO Lite IP too.
At the end of the day I get the same error:
Error (176202): The differential I/O standard Differential 2.5-V SSTL Class I cannot be used on the pin RC_A[0], because the specified pin uses a tri-stated output buffer.
Is it only possible to have either a dedicated input or output differential port?
Why is it even letting me configure the IP as a bidirectional differential IO?
Or am I missing something when it comes to pin configuration?
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    May I know what the exact Pin's name that you assigned?
    >> Can you share the snapshot of this?
    Aqid
